Woody
Woody GRM+ Memberand UltimaDork
5/6/12 7:02 p.m.
I've never needed to use them before, but I just scored a set of wheels that will require the use of 15mm spacers on the rear. They seem simple enough, but is there any brand of spacers that stands out from the others?
chandlerGTi
chandlerGTi HalfDork
5/6/12 7:24 p.m.
I always mic them in a couple places and check the by patterns before rolling on them. Anyone with a CNC can make a good set though.
emodspitfire
emodspitfire Reader
5/6/12 7:35 p.m.
Don't forget that spacers generally require new/stronger/larger bolts or wheel studs..... (even if the wheel center over the bearings does not change.)
Rog
92CelicaHalfTrac
92CelicaHalfTrac MegaDork
5/6/12 7:37 p.m.
At 15mm you can get bolt on spacers. I would suggest those.
wbjones
wbjones UltraDork
5/6/12 8:03 p.m.
these:
http://www.ichibausa.com/SearchResults.asp?Cat=53
this is what I've used:
http://www.trakplus.com/ ..... http://www.trakplus.com/ (go to the bottom of the page
9mJVWsOp24BgIB6yW7BkPHr3iQtVOaxWc8Kh7mDZdc3hSNtOc4v7LRXSccGFy8Rx
