stan
stan GRM+ Memberand SuperDork
11/19/09 5:38 p.m.
Here's my question: Steel wheels are usually thinner, so if you change to a aluminum wheels can there be a stud length problem? It looks like I've went from the lugs being threaded onto a stud about a half inch long to one being about a quarter inch long and I'm just wondering if there's a minimum recommended length for studs.
I have this imagine of all of the studs breaking at the same time on the freeway.... Ouch.
Thanks
iceracer
iceracer HalfDork
11/19/09 5:54 p.m.
What actually counts is the lug nut itself. No matter how long the stud , as long as the nut screws on it's full thread.
DILYSI Dave
DILYSI Dave SuperDork
11/19/09 10:51 p.m.
You want thread engagement at least as long as the bolt (stud) diameter.
2002maniac
2002maniac Reader
11/19/09 11:00 p.m.
The MOST important thin is making sure you have the right lugnuts for the wheels. There are various different styles available such as: conical, acorn, and round.
stan
11/20/09 11:12 a.m.
...so a quarter inch diameter bolt should go into the lug at least a quarter inch.
And I know what you mean about the lugnut and wheel being compatable.
thanks.
NYG95GA
NYG95GA SuperDork
11/20/09 11:55 a.m.
Most lugs are more like a half inch diameter. Also be sure to check the hub clearance; sometimes when running rims from a different make, the center bore will not fit, even though the bolt circle does. When attempting to fit Celica rims on my Neon, I found I had to overbore the rim's center by ~2mm to get them to clear the hub.
stan
11/20/09 1:30 p.m.
In reply to NYG95GA:
True dat. I'll check that when I get home (and it's daylight!).
thanks, Stan
P8AcH0Y8TTW3w6CMQKMGDwlH26pDWihKML6kyFsunZTQMp8ta6KeKbUqb2kqXXFY
