Hasbro
Hasbro Dork
5/29/12 5:04 p.m.
This is my last attempt to find these. SSR will custom make them for $600 but that's too rich and they are too heavy. Maybe one of you knows of a make that I haven't found. I'd consider 8.5 also. Offset around 30-40. Thanks.
EvanB
EvanB GRM+ Memberand UberDork
5/29/12 5:07 p.m.
Starion/Conquest with the special handling package (SHP) had 16x9" in 5x114.3 in the rear. Offset was 0mm though.
chandlerGTi
chandlerGTi HalfDork
5/29/12 5:15 p.m.
Or you can dual drill your hubs to 5x130 and have a plethora of options.... or have some other pattern wheels filled and redrilled.
z31maniac
z31maniac UberDork
5/29/12 5:18 p.m.
Hasbro wrote: This is my last attempt to find these. SSR will custom make them for $600 but that's too rich and they are too heavy. Maybe one of you knows of a make that I haven't found. I'd consider 8.5 also. Offset around 30-40. Thanks.
SSR............heavy?
Hasbro
Hasbro Dork
5/29/12 5:26 p.m.
Yup, 19 lbs. I asked him if he was sure and he said yes.
Man, you guys are quick!
Hasbro
Hasbro Dork
5/29/12 5:28 p.m.
chandlerGTi wrote: Or you can dual drill your hubs to 5x130 and have a plethora of options.... or have some other pattern wheels filled and redrilled.
Would this be for new wheels or older ones?
mndsm
mndsm UberDork
5/29/12 5:38 p.m.
http://esmwheels.com/access/wheels-009r-009r-p-88.html
failboat
failboat Dork
5/29/12 5:40 p.m.
SN95 V6 Mustang alloys are 16x8 I believe.....offset around +20. 5x114.3
ProDarwin
ProDarwin SuperDork
5/29/12 6:12 p.m.
EvanB wrote: Starion/Conquest with the special handling package (SHP) had 16x9" in 5x114.3 in the rear. Offset was 0mm though.
Some MKIV Supras had uber-wide 16" wheels with that pattern. 16x9 rear 16x8 front IIRC
I know the rear Z32 Turbo wheels are 16x8.5 in with that pattern as well. 35 offset.
I think both of these are around 19lbs though :(
ST_ZX2
ST_ZX2 HalfDork
5/29/12 6:30 p.m.
Mazda RX7 wheels (93+) are 16x8, ET50 and about 15 pounds as I recall. Oh, and I have a set.
mw
mw Dork
5/29/12 8:11 p.m.
If you a double drilling, I'd go 5x4.75" so you can use Camaro rims. I think 16x9's were pretty common.
Hasbro
Hasbro Dork
5/29/12 10:10 p.m.
I should have specified 15 lbs. max. I can do a 17x9 but really want keep the weight down, hence the 16s. I imagine I'll have to go with 16x8 RPF1s, which will reduce stock wheel weight by 28 lbs. Now, with Keiser 15x9s, at 10.5 lbs I could save 40 lbs. but guess the performance trade off might be a problem? (R888s) Sorry, rambling.
uwvErSFjcEuVmOjLqjFrnISQ7lZSILsK0ruqE7HMFWWqjJRSjFm5VGYe0uRnXh13
