Trackmouse
Trackmouse UltraDork
3/26/18 2:16 p.m.
https://www.fastenal.com/products/details/38631
m8-1.25x120mm.  Basically the shaft of the board needs to be 4 inches and the threads need to stick out a hair longer than that. This is for spacing my sub frame blocks for the front stabilizer bar brackets. I posted about that a few days ago. Now I know what I need, but Home Depot and Lowe’s don’t have long enough votes Everything they have is 90 mm. The Internet sure doesn’t have a whole lot, that’s for sure
tuna55
tuna55 MegaDork
3/26/18 2:20 p.m.
So... why not walk into your nearest Fastenal and buy it?
Stefan
3/26/18 2:24 p.m.
Is there a Parkrose or TrueValue hardware store near you?
Is there a Fastenal?  They do have brick and mortar stores
All of the above often have a better metric hardware selection.
Something to think about:  Use a stud instead of a bolt if that helps with your search.
Worst case?  hit the local salvage yard and find some from another vehicle that are proper length.
tuna55
tuna55 MegaDork
3/26/18 2:25 p.m.
Branch Code: ORABY
Hours: Monday - Friday 7:00am - 5:00pm
Phone: (541)928-7326
Fax: (541)928-7346
2475 Ferry St SW
Albany, OR USA 97322
Map and Directions
Set 'ORABY' as My BranchBranch Code: ORLEB
Hours: Monday - Friday 7:30am - 5:00pm
Phone: (541)258-1731
Fax: (541)258-1753
2175 S. Santiam Hwy
Lebanon, OR USA 97355
Map and Directions
Set 'ORLEB' as My BranchBranch Code: ORCOR
Phone: (541)753-2064
Fax: (541)753-2066
1490 SW 3rd St.
Corvallis, OR USA 97333
Map and Directions
Set 'ORCOR' as My BranchBranch Code: ORSA1
Hours: 7AM-5PM
Phone: (503)375-0660
Fax: (503)375-0662
1985 16th Street NE, Suite 170
Salem, OR USA 97301
Map and Directions
Set 'ORSA1' as My BranchBranch Code: ORWOD
Phone: (503)982-5354
Fax: (503)982-3260
2225 North Pacific Hwy Ste B
Woodburn, OR USA 97071
Trackmouse
3/26/18 2:27 p.m.
Alternatively, how could I extend a shorter bolt, longer?
Trackmouse
3/26/18 2:35 p.m.
Fastenal can get them. It’ll be next week. FWIW, my spacers are 4”, so the bolts need to exceed that by enough to thread in. I did just find some 110mm at the ace in bend. The one in the neighboring town over only had 100mm length.
Trackmouse
3/26/18 2:37 p.m.
I didn’t even think of this! Good idea man!
daeman
daeman Dork
3/26/18 2:39 p.m.
For an interim idea, how about threaded rod? Sold in lengths of a few feet, all you need to do is cut lengths and put a nut on the end.
Trackmouse
3/26/18 2:44 p.m.
In reply to tuna55 :
Sadly, while those are “near”. They are at least a two hour drive over the mountain pass. I’d just wait till next week if that were the case. But thanks!
jimbbski
jimbbski Dork
3/26/18 2:47 p.m.
Sometimes the bolt you need is as close as your nearest Pick-n-Pull.
I've sourced many a metric bolt by just walking around their yards and removing a bolt that looks alike it will suit my needs.
Then it just put it in my pocket and I'm on my way.
Jaynen
Jaynen UltraDork
3/26/18 2:48 p.m.
I ordered from McMasterCarr and it was like overnight. crazy fast
PseudoSport
PseudoSport Dork
3/26/18 2:48 p.m.
Try boltdepot.com Maybe they can get them to you a little quicker?
tuna55
tuna55 MegaDork
3/26/18 3:02 p.m.
So that's a good source, but it's totally stealing. I am sure they won't charge you much for it.
Cousin_Eddie
Cousin_Eddie Reader
3/26/18 3:05 p.m.
McMaster. I just looked and they have them in steel and stainless steel. Order now, they will ship it today and you'll have it in a couple of days. McMaster don't fool around. They ship lightning fast.
Trackmouse
3/26/18 3:07 p.m.
If these bolts from ace don’t work I’ll try the threaded rod/stud route. Seems easier.
Pete Gossett
3/26/18 4:12 p.m.
In reply to Trackmouse :
Any Tractor Supply or similar farm stores nearby? They have a much better selection of metric hardware than LowesDepot.
sergio
sergio Reader
3/26/18 4:17 p.m.
Go to a Toyota dealer service department. Ask one of techs if they have a bolt like what you’re looking for. Bet they have a bucket with used bolts and nuts that will have it
Trackmouse
3/26/18 4:35 p.m.
In reply to Pete Gossett :
Do have a Coastal nearby.
@sergio, dealer won’t have this. This is a type of bolt they wouldn’t put in any car! Lol. Mostly due to the extreme length vs. shaft diameter.
snailmont5oh
snailmont5oh HalfDork
3/26/18 5:03 p.m.
Then there is the moral argument of stealing versus stealing. [/hijack]
Trackmouse
3/26/18 5:50 p.m.
In reply to snailmont5oh :
Explain.
stuart in mn
stuart in mn UltimaDork
3/26/18 6:16 p.m.
My local Ace hardware store has a pretty good selection of metric bolts.  If you have one nearby check them out.
Cousin_Eddie
Cousin_Eddie Reader
3/26/18 6:29 p.m.
If you'd have ordered from McMaster Carr, you'd already have a tracking number by now.
yupididit
yupididit SuperDork
3/26/18 6:54 p.m.
Look for a local bolt store. They're usually cheaper and don't have to wait for a shipment.
Tyler H
Tyler H GRM+ Memberand UltraDork
3/26/18 7:25 p.m.
It's only stealing if you don't buy anything else.  If you buy the nuggets, the sauce is included.
Trackmouse
3/26/18 10:08 p.m.
In reply to Tyler H :
Lmao!
Cousin Eddie, you’re only reader status, can’t trust you yet. (Joking sarcasm!) if I ordered now, would I have it by Friday?
Fyi, the 110mm was too short. It needs that extra 10mm to thread in. So back to either waiting for “chafe-n-y’all” to come through Monday. Or, I trust “cousin Eddie” lol.
but right now, I’m durnk. So tomorrow I’ll check for studs like Stefan suggested.
heeKUe92ZoLDSxdRqbfVmWdWNnGY8bEdDmBMUQMstGiUJoY8Fmf5IMgRnTZeUDS5
