DukeOfUndersteer
DukeOfUndersteer UltimaDork
2/20/20 9:02 a.m.
Have a funky wiring question to ask for my fellow automotive gum shoes. I have recently acquired an old AIM MXL dash out of a crashed racecar that I wanted to put in my little Lexus IS300. I was planning on just going straight to the OBD2 port to get my power, ground, can lo and can hi outputs. Reading on the Lexus forums, they give a pin out on all the applicable pins needed. So, I try it, no go. I can power it up, I can see battery output, but that is all. Any good leads without having to strip wires and butt-connect (I'm really hoping I don't have to go this route) or is this just a lost cause.
Thanks fellas!
TGMF
TGMF HalfDork
2/20/20 9:06 a.m.
Nothing helpful to add here....other than that steering wheel looks out of place in a IS300 of this vintage.
Kendall_Jones
Kendall_Jones HalfDork
2/20/20 9:06 a.m.
I may have an obd2 adapter for the aim system, I can check later today.
Kendall_Jones
2/20/20 9:09 a.m.
Also, do have the aim software?   It's free and allows you to connect / configure the display.  There are settings for the can / ECU setup,  your might be set for some other ECU or turned off.
DukeOfUndersteer
2/20/20 9:11 a.m.
In reply to TGMF :
;) $40 pull-a-part wheel, found where to adapt the old push button shifters to convert over to the paddles
DukeOfUndersteer
2/20/20 9:12 a.m.
In reply to Kendall_Jones :
I do have the Aim software. I'll have to try plugging in and reconfiguring the dash. Just gotta find that pesky cable
Kendall_Jones
2/20/20 9:34 a.m.
In reply to DukeOfUndersteer :
I wound up making my own cable from a headphone cord & usb cable.  The schematic is in the pdf manual.
DirtyBird222
DirtyBird222 UberDork
2/20/20 10:25 a.m.
DukeOfUndersteer said:
In reply to TGMF :
I need to get the Lexus GX470 wheel for my Sequoia. Nothing classier than some wood grain and I ain't paying the $300 premium on ebay either lol
qD3iRcPbNIOXF5uTgHXNR9z4t1IApD9K9IFNJGqgYezxpiRzEGJYm8PUDRhYPYaP
