bluej
UberDork
12/26/19 6:42 a.m.
Say you wanted to make the compromise of keeping with an auto for a daily driven and track day vehicle (think congested traffic commute, so all sorts of compromises), what would you pick if you were looking on a reasonable GRM budget ($2-500?). Vehicle is an e46, so bonus points for playing nice there. 4L60/80 w/ microsquirt control sounds like the easy button purely on the face of it if you're likely to be using megasquirt for the efi end of things, but I really don't know. I'd rather go that route over HP tuners (better fit for me for at least the near term), but could be convinced.
TH400 with a manual valve body might do it for me, but I have no confidence in my ability to work with modern electronically controlled transmissions.
bluej
UberDork
12/26/19 6:54 a.m.
Looks like the 5l40e is on the list, at least partially. Since that's the trans already in the car, that sounds promising. I may be able to come at that from the BMW control end of things since one generation of the e46 ecu's seems thoroughly hacked.
So is a refreshed 5l40e up to track day use behind a warmed up 5.3?
In reply to bluej :
there are a couple or companies that make paddle shifters for the 4/6 speed electronic gm boxes. 4l60/80 6L60/80
https://www.tciauto.com/paddle-shifter-without-display.html#
The BMW non-AWD version, the M82:
" It is designed for service in vehicles up to 4000 lb (1814 kg) GVWR and in service was mated to a selection of final drive ratios 3.42:1, 3.73:1, or 3.91:1 depending on the carline. The 5L40-E had been designed for 1.8–3.6 L engines with a maximum of 250 ft·lbf (340 N·m) of torque. It was underrated when used in combination of M57D30 engines. As the M57D30 rated torque output of 390/410Nm."
It appears on the surface that that transmission won't last long behind the power of your 5.3 but I only know what I read on the internet so take that with a shaker of salt
bluej
UberDork
12/26/19 11:38 a.m.
In reply to MrChaos :
That's interesting. I'm ok w/ bumping the stock location, though.
bluej
UberDork
12/26/19 11:39 a.m.
I need to research 5l40 vs 5l50 differences I think.
it seems like everyone goes with 4l60,4l80,6l60, or 6l80's for a reason
5L50 isn't really up to the torque requirements, is it? I remember idly looking at the specs on these and they seem interesting, and Megashift can control one, but I don't know about 5.3's torque not hurting one fast.
200-4R if you don't like the 4L6x's ratios? 4L80's seem to have a pretty nice ratio spread like the 200-4R did.
_
Dork
12/26/19 4:58 p.m.
MrChaos said:
In reply to bluej :
639$ for that?!?!? Insanity. I could adapt a paddle shift from a sim rig for a LOT less.
