logdog
logdog GRM+ Memberand SuperDork
2/6/16 11:26 p.m.
Apparently my Google skills are weak.
I am looking for a cheap way to see Cam Retard Offset on a GM 5.7 Vortec. This is a PID usually reserved for higher end scan tools since its not part of the generic OBD2 package. My OTC scanner does not show it. I dont want to spend the hundreds on a fancier scanner just for one feature. I have heard good things about Torque Pro but cant seem to find anything other than people posting the same question.
Does anybody know?
logdog
2/6/16 11:28 p.m.
For those that dont know, being able to see Cam Retard Offset is helpful after replacing a distributor.
Bumboclaat
Bumboclaat Dork
2/7/16 12:05 a.m.
I don't see that that is one of the "sensor" entries that is available for real-time monitoring in Torque Pro.
Knurled
2/7/16 5:27 a.m.
Which OTC scan tool are you using? I had never had a problem seeing that in a Genisys. Havn't tried that with the Genisys Touch, we just got that last year and haven't seen any 5.7s yet.
ultraclyde
ultraclyde UltraDork
2/7/16 7:06 a.m.
I'm no help on GM, but I've been playing with Torque Pro on my old powerstroke a lot. Even if the app doesn't have a preset for it, you can write a custom one IF the data is actually being sent to the computer AND you can find out the PID number. Several of the PIDs I'm using are custom ones that I found in forums for the early diesel ford trucks that weren't in the stock Torque lists. I'm not sure how you could identify the pid #s and coding, though.
logdog
2/7/16 9:09 a.m.
Knurled wrote: Which OTC scan tool are you using? I had never had a problem seeing that in a Genisys. Havn't tried that with the Genisys Touch, we just got that last year and haven't seen any 5.7s yet.
Its one like this. 10-12 years ago it was the cheapest I could find with basic live data. It was good for the used cars that came through the shop and since I retired from flat-rate its been good for personal cars. However it does have its limits.
logdog
2/7/16 9:14 a.m.
Thanks for checking in Torque for me. I was hoping it would be there but am not surprised it isn't.
qlN4q3xP1kxuHfCo76ltrpCb8SfSQsiwMS6reTNngNZ9uI8lVlUMPpx76Fi98uKK
