DannyDattos
DannyDattos New Reader
4/27/24 5:36 p.m.
My tow pig has decided to stop starting. You can hear the starter spinning, but it does not engage the flywheel. (Bendix is not stickin' out) I have cleaned and replaced every connection from the starter to the battery to the ignition, replaced and cleaned grounds. I took starter off and bench tested it, worked flawlessly. The starter solenoid is built into the starter, and not in a way that I could bridge the gap with a setta pliers. It's a crapshoot but any ideas on what I'm missin'? 318 throttlebody injection.
Russian Warship, Go Berkeley Yourself
Russian Warship, Go Berkeley Yourself PowerDork
4/27/24 7:43 p.m.
How are the teeth on the flywheel/torque converter?
You could also just run a jumper to the solenoid from the battery or jump the starter relay on the fender.
Streetwiseguy MegaDork
4/27/24 7:45 p.m.
That's either a busted starter drive, or a flywheel with teeth missing.
buzzboy
buzzboy UltraDork
4/27/24 8:08 p.m.
Bar the engine over a half turn and check again?
4/27/24 10:05 p.m.
It's the starter.  Just because it works on the bench doesn't mean it works when under load.
The overrunning clutch is probably now a bidirectionally overrunning clutch.
lfqnXASZ27RLMwh9zpoJjmuyM7JtnE35g1Nj5GVBMTDfMgBdqDswrmGKf1lKG6MM
