joepaluch
joepaluch New Reader
11/9/09 9:10 a.m.
The 944 engine bay is probably not wide enough. I did see a 944 tub with a 911 motor. Anything is possible, but they may have had to tube frame the front end. 928 motors are too wide and also require a tube frame front end. Chevy V8's will fit with relative ease and given the cost, effort and performance gains probably the best way to go. Really what good is it to replacea 2.5L 4 with a 2.0L flat four? You can get 500 hp from the 2.5L 4 using a good turbo the same way you can from a subie motor.
If you want big power with little effort go with a chevy V8. If you want boosted power get a 944 turbo and play with that. One thing to consdier is that running 400+ hp will requrire alot of updates to the chassis to handle that power. You can get an easy 300 whp from a 944 Turbo with very limited chassis updates and if done right a very reliable powerplant. At 350 whp things begin to change and at 400 whp the stress you put on the chassis requires attention. The parts are there to upgrade, but not doing so ruins the balance and reliablity of the car.
Tetzuoe
Tetzuoe Reader
11/9/09 10:00 a.m.
I know the LS swap is well documented and may be un-fun (im doing one myself atm ) but if you want dimensions check out the hybriders websites (944hybrids.com, in the forum gallery) we have full dimensions and drawings up there, basically you just have to get the right number of splines on your clutch, the right placement, and the appropriate bellhousing.. mate that up to the transaxle and your golden.
also the transmission tends to grenade around the 4-500 hps, so youd do well to take one apart and get the syncros bead blasted.
Tetzuoe
Tetzuoe Reader
11/9/09 10:08 a.m.
ah, crap, fiat2turbo beat me to the punch, 944hybrids.com is way more technical tho, check it out
OBKa3HKJW5hRP7EXFADj0nsrN4oFUoll3IXr1J9SNVmKV4S2l47DGstp3W0vWIfh
