Teggsan
Teggsan New Reader
11/26/11 12:58 p.m.
I have a line on an XJ8 that has the engine partially apart. Not sure what the problem is (for some reason either the owner doesn't know or isn't telling) but the rest of the car looks really good.
What's the worst that could happen?
dean1484
dean1484 GRM+ Memberand SuperDork
11/26/11 1:04 p.m.
once you fix the motor you have to fix the trans. Those motors are not the greatest and the trans are usually an issue as well.
Now if the rest of the car is in perfect condition it is the perfect candidate for a 4.8, 5.3 LSX, LM4,7 etc. GM motor and trans swap.
SyntheticBlinkerFluid
SyntheticBlinkerFluid Dork
11/26/11 1:06 p.m.
A 4.8L/4L60 combo would be perfect.
aussiesmg
aussiesmg SuperDork
11/26/11 4:43 p.m.
SyntheticBlinkerFluid wrote: A 6.0L/T56 combo would be perfect.
FTFY
Woody
11/26/11 5:29 p.m.
I'd contact one of the Jaguar swap guys like John's Cars and see what they say. They may not have done engine swaps on XK8s yet, but I'm sure that they've put some thought into it.
bearmtnmartin
bearmtnmartin GRM+ Memberand New Reader
11/27/11 5:13 p.m.
Heres another one with a good engine. Its probably cheaper.....
http://abbotsford.en.craigslist.ca/cto/2720548065.html
11/27/11 5:26 p.m.
FTFY
While yes that would be the fun thing to do, I'm am a cruiser kinda guy when it comes to large cars.
Teggsan
Teggsan New Reader
11/27/11 6:10 p.m.
More info: according to the owner it's a "bad timing chain." Not sure what additional damage may be found. May go to see it mid-week.
My guess is that either this is a repair where the owner is in over his head, or a bent engine that's going to cost too much for the owner to fix. Leaning toward the latter, based only on a few text messages.
Schmidlap
Schmidlap HalfDork
11/27/11 6:48 p.m.
The Jaguar V8 is an interference engine so if there's a problem with the timing chains, chances are there's now a problem with valves, pistons, etc. If he just has the front of the engine apart, make sure you check the valves.
If the valves and such check out, I'm pretty sure the Lincoln LS V8's timing chains/tensioners are identical and are a lot cheaper than the identical part from a Jag dealer.
My vote would be LSx/4L60E although figuring out the electronics to keep the car happy might be a huge pain.
Continental Imports talks about Timing Tensioner Failure
Bob
mOIPQRLFqw3Iz2z7GVDHS5FsvwhWmq803P6kIWlh7ceG0ovBjRYop7H5skF2PsoS
