So I got the opportunity to drive / ride a Can Am Spyder last weekend. It was the fancy touring model with heated seats, an electric windshield, and an automatic transmission. It was fun, kind of twitchy, and reasonably quick (I didn't push it though).
I may be the only one on the planet who managed to stall one too, much to my dismay. It has an AUTOMATIC TRANSMISSION and I came to a stop like I did a few other times on that ride when I was about to make a U-turn. Well, this is when it bucked a few times and conked out, just as if I had forgotten to pull a clutch lever in (which it doesn't have). The owner said later that this has never happened to him and he laughed at me.
Um, to start it, you are supposed to be in Neutral (or this is what I was told), then you need to turn the key on, then push "MODE", then switch on the ignition, then push the starter. Nothing happened. I noticed that the indicator kept saying 1st Gear, so I was trying frantically to switch it to Neutral. Nothing. Fortunately, I left my cell phone at home, so I couldn't call the owner and ask him. So I sat there with the owner's manual going through the starting procedure (while bikers kept stopping to ask if I was OK... how embarassing). The starting procedure was vague, so the book was useless, except that it did state that the bike would automatically switch to neutral upon startup so it doesn't matter which gear it is in. I did figure it out, though.
Starting procedure. First, turn off the key and wait for computers to shut down. Second, turn the ignition switch from RUN to STOP. Third, turn on key and wait until the computer boots up. Fourth, press "MODE". Step five, switch ignition switch to RUN. Step six, step on brake pedal. Step seven, press ignition switch and VOILA! It runs! Easy, right? It took me 20 minutes to figure that out.
Overall, it was fun ride. I'd like to ride the sport one as well to see what the difference is.
