ronholm
ronholm HalfDork
2/27/14 8:55 a.m.
First in the new forum!
The ride as it came home! (about 4 years ago)
ronholm
ronholm HalfDork
2/27/14 8:59 a.m.
The builder enjoying it in the 70's
ronholm
ronholm HalfDork
2/27/14 9:07 a.m.
The engine "bay" after some tinkering..
messing around trying to get it to start in the cold, constant tinkering lead us to today.
Which of course is a Intercooled VNT 2.2L dodge running 1990 SBEC electronics.
As of today the rail starts and runs.. awaiting axles to take it for a drive.
I have added
(cheapo) rack and pinion 3X3 (three inches wider and longer) Trailing arms. 3 rib bus transaxle. Modified seats so my 6'5" butt will fit. CNC pedals which are adjustable. Removable steering wheel. Disk brakes.
Turn signals (self canceling) heated seats.
and a bunch of other stuff I am forgetting.
ultraclyde
ultraclyde SuperDork
2/27/14 9:09 a.m.
that's. AWESOME.
edizzle89
edizzle89 New Reader
2/27/14 11:03 a.m.
i have a real soft spot for rails. that thing is legit
Toyman01
Toyman01 GRM+ Memberand UltimaDork
2/28/14 6:52 a.m.
I really wanted a buggy when I was younger. I even had one for a while. Unfortunately I was broke at that time so I never got it running. I still have the fiberglass body panels off of it leaning against the wall behind my shop.
ronholm
ronholm HalfDork
3/6/14 9:47 a.m.
Last night I was able to start it and move it under its own power for the first time in more than three years.. To late and to loud for a test drive it isn't really ready for.. Looking to go for a spin friday...
It sure feels good! I was getting pretty tired of looking at it not running.
Toyman01
3/6/14 3:48 p.m.
Pictures and video will be required.
ronholm
ronholm HalfDork
3/7/14 5:54 p.m.
Well damn... Now I have gone and done it.. Working on the rail and trying to keep it in the shop fixing things.. and instead I half ass a bunch of wiring and nonsense together and take it for a spin...
Now the damn thing is all covered in mud... A complete mess...
http://youtu.be/nf7jtQtavzs
Nitroracer
Nitroracer SuperDork
3/8/14 4:59 p.m.
Looks like a fun ride even if it was halfassed
Pat
Pat HalfDork
3/8/14 6:09 p.m.
Looks like a screamer!
ronholm
ronholm HalfDork
3/9/14 1:32 p.m.
Pat wrote: Looks like a screamer!
In aircooled form it was barely over 1200 lbs fully loaded. I couldnt have added more than 125-150lbs with the engine and stuff. And a couple hundred pounds of extra gear/upgrades. So it still should be light enough to not need all the power it now has
92" wheel base. Makes it easy to toss around in the woods.
Now to fix some of the wiring. For some reason it struggles to turn over when warm and not idling well.
And I need to sort out some kind of surge tank for the fuel. The gas tank really fits nice where it is in front of the engine, but makes working on anything really tough.
ronholm
ronholm HalfDork
3/9/14 11:48 p.m.
So I got bored the other night and instead of spending a couple hundred bucks on gauges figured I could have them for nearly free if I spent several days rigging something together...
So you take two of these
Cut them into pieces... Take the soldering iron and do some plastic welding and end up with something like this..
Still need to make a bezel... but I think I have a plan.. and then form a nice console
GRM enough for ya'll?
petegossett
petegossett GRM+ Memberand PowerDork
3/10/14 5:50 a.m.
In reply to ronholm:
Sweet!
Pat
Pat HalfDork
3/10/14 6:04 a.m.
Awesome!
Toyman01
3/10/14 7:49 a.m.
Very cool!
ronholm
ronholm HalfDork
3/10/14 7:52 p.m.
More GRM for ya'll...
Old Spotlight buckets can always be found cheap at swap meets... The trouble is I need DOT headlamps...
So.. Some halogen sealed beams.. But how to make them fit...
Yep... Old door panel clips work GREAT, and I have found work even better than the "w" clips you can buy..
Cotton
Cotton SuperDork
3/11/14 5:56 p.m.
I love it!
bgkast
bgkast GRM+ Memberand Dork
3/11/14 6:00 p.m.
I'm stealing your headlight idea. I like the look much better than the typical sealed beam buckets.
ronholm
ronholm HalfDork
3/13/14 10:15 a.m.
More GRM... BMW dimmer control for dash lights... Left over from working on the 89 750il... The buggy feels more luxurious already.. I would have just used the headlight switch from the dodge.. but it doesn't fit my overhead panel very well.
Oh... and Turns... Those are momentary switches with "angel eye" LED's in green. Using a Signal dynamics 1007 module pushing the momentary for one second causes the turn lamps to flash for 7 seconds.. Hold the switch for two seconds and they run for 20.. Push both buttons and the hazards flash... Push buttons again to cancel if needed..
The front lamps are wired with a 10 dollar relay module to use a single filament lamp. I simply used the "brake" and "turn inputs" on the trailer module.. Works great!
Signal Dynamics has another module which will handle the running lights also.. But it means running lights are on all the time.. and I wanted to be able to shut them off..
bgkast
3/15/14 9:40 p.m.
That signal dynamics relay is slick, but a bit spendy. I'll have to remember it and see how lazy/cheap I'm feeling when I get to that point on the Midlana.
Vigo
Vigo PowerDork
4/22/14 1:19 p.m.
Did you rehost that youtube video anywhere else? The link is dead now and i missed it the first time around.. i want to see it!
ronholm
ronholm HalfDork
4/22/14 3:08 p.m.
What the heck? Why would my youtube channel be gone?
ronholm
ronholm HalfDork
4/22/14 5:33 p.m.
There we go... Video link above should be fixed.. berkeleying google.. Apparently some google plus listing linked to an old email account was linked to my youtube account... and somehow went unverified causing it to be flagged as spam...
problem is not much work is happening to the buggy right now... Priorities you know..
Hx0cNk0EFaKxrditev0ZextcXxrUzyoQ0XqKHBj9TGxAjjAAJog08UMW0N7ymHoX
