alex
alex SuperDork
10/5/11 12:03 p.m.
Okay, don't answer that.
So, I have this plain jane '88 GMC 1500 that I really like. Just an honest work truck. So, of course I want to do bad things to it.
I'd really like to build it into a bit of a sleeper - keep the utility cap on the bed, tired (or at least refreshed stock) paint, maybe the slightest little drop, but with some guts underhood.
This '77 "farm truck" is truly inspiring.
Obvious answers include LSx or good ol' BBC, and that's all well and good. However, I have this 460 Ford motor on a stand, half rebuilt, that should be good for around 500hp/tq with very little work... You see where I'm going with this.
How bad an idea is this? I'd obviously be in for a fair amount of fab work, and I'd have to hook up the right transmission (probably a C6, since the 460 would probably grenade a T5 and a T56 is too spendy for me). Then there's the obvious sacrilege of the Blue Oval wearing a Bow Tie, but that actually goes in the Pro column for me.
Talk me out of this.
JThw8
JThw8 SuperDork
10/5/11 12:07 p.m.
FWIW I had a chevy 400 small block in a 79 Ford F250 so you will just be equalizing the balance.
DoooItttttt
alex
alex SuperDork
10/5/11 12:13 p.m.
I'd hate to pass up the opportunity to restore balance to the universe.
Slightly off topic question: did the 4L60 ever have a 454 in front of it? Just researching my options here.
1988RedT2
1988RedT2 Dork
10/5/11 12:17 p.m.
Sounds like fun to me. I'm not biased in any way, but I will mention that I have an '85 C-30 Dooley that is in fantastic condition, and I'm looking to drop some (more) money into it pretty soon.
Grizz
Grizz HalfDork
10/5/11 12:23 p.m.
I was gonna suggest something about a duramax, but it would kill the whole sleeper thing you're going for since everyone expects them to be fast anymore.
alex
alex SuperDork
10/5/11 12:31 p.m.
To make matters worse, I have this fantasy of building the thing enough to warrant a full cage that's triangulated to the rear of the frame, hidden under the utility cap and painted the same drab tan as the exterior, so as to not arouse suspicion to anybody poking their head in the cab. That, though, would be my HPDE version of the fantasy build, with a Hotchkiss TVS front end (or maybe a custom tubular front subframe with a-arms, dropped way low, and with the entire front end replicated in fiberglass to help with weight balance. Naturally, that would get an LS9/T56.
God help me.
Grizz
Grizz HalfDork
10/5/11 12:33 p.m.
He is. He's sent you here, so we can all say do it and get you started.
aggravator
aggravator New Reader
10/5/11 12:39 p.m.
alex wrote: Talk me out of this.
I doubt that anyone on here would do anything to discourage you.
DO IT!
JThw8
JThw8 SuperDork
10/5/11 12:52 p.m.
alex wrote: I'd hate to pass up the opportunity to restore balance to the universe. Slightly off topic question: did the 4L60 ever have a 454 in front of it? Just researching my options here.
All the 454s I've seen were backed by the 4L80 but that's by no means a definitive answer.
bravenrace
bravenrace SuperDork
10/5/11 1:43 p.m.
The truck in the vid isn't a 77. It's a '68-'72. I have a '77 and a '78. They both came with 454's from the factory. I can tell you that to build a sleeper, that's all you need to start with, not that something else won't work. A 4l60 will never live behind a healthy 454.
Grizz
Grizz HalfDork
10/5/11 1:49 p.m.
I want one of the shortbed Dodge Warlocks with a factory 440.
Build it up with highway gears and three speed column shift. Stupidly high top speed here I come.
ultraclyde
ultraclyde HalfDork
10/5/11 2:34 p.m.
I was thinking of similar project ona smaller scale - a Ford Courier with a high-boost 2.3l and Tbird IRS....even the hidden cage idea....
so do it already!
pilotbraden
pilotbraden HalfDork
10/5/11 2:59 p.m.
I was impressed 23 years ago by Corn Yella. It was a 1972 Chevy 1/2 ton long box, 400ci, three on the tree and a coilspring rear suspension. That mutha got down in a straight line. Stopping and turning were hair raising. It was owned by a mechanic at the dealership where I worked. We burned up a pile of used tires on it.
Gearheadotaku
Gearheadotaku GRM+ Memberand Dork
10/5/11 9:18 p.m.
a 4-speed manual M22 muncie should hold up to a big block with proper prep work and be cheaper than a T56. For Auto I'd go TH400. If you're just drag racing, you don't need overdrive. Proper gear and tire size selection should get you livable hi-way RPM.
Did anyone notice the red Triumph that beat it?
Grizz
Grizz HalfDork
10/5/11 9:55 p.m.
Gearheadotaku wrote: Did anyone notice the red Triumph that beat it?
I noticed the noise it was making.
EdenPrime
EdenPrime New Reader
10/5/11 10:26 p.m.
If you thought you'd ask the guys at GRM to talk you out of dropping an engine in your truck that's way more than what's necessary or safe-- then you'd better keep surfin' the 'net.
alex
alex SuperDork
10/6/11 4:02 a.m.
In reply to Gearheadotaku:
You mean M22 + BBC, right? Or are they mated to 460s commonly?
1988RedT2
1988RedT2 Dork
10/6/11 6:10 a.m.
I wonder if that was the stock powerplant?
ultraclyde
ultraclyde HalfDork
10/6/11 7:40 a.m.
in something, sure. But I'm bettin' it weren't no triumph!
Gearheadotaku
10/6/11 8:34 a.m.
alex wrote: In reply to Gearheadotaku: You mean M22 + BBC, right? Or are they mated to 460s commonly?
BBC + M22 if you want to keep it in the family. If you're going Ford power, (sacrilege! ) I'm not sure what 4-speed they used behind their big blocks, T10 maybe?
pilotbraden
pilotbraden Dork
10/6/11 9:36 a.m.
My Ford 390 is mated to a New Process 435
Ranger50
Ranger50 Dork
10/6/11 10:37 a.m.
Manuals in the trucks with a 460 are all cast-iron monters. Never was a true 429-460 based BB 1/2 ton truck. Only were available in the 3/4 tons and up. Newer versions were an alum cased ZF deal.
Now if you want to talk the cars, they were almost always Toploaders.
Bobzilla
Bobzilla SuperDork
10/6/11 11:17 a.m.
Sell 460. Buy 8100/4L80e and a cam/tune. Done.
bravenrace
10/6/11 11:33 a.m.
8100? That thing is a pig, and not the best platform to build on either.
fasted58
fasted58 SuperDork
10/6/11 11:42 p.m.
image kinda grainy large screen, TR-4 or TR-6 w/ obvious V8... popular swap is 5.0.. or FTW an LS
GTFFb3Gyg4tvH7yLC69ETGFXv5YRG6WJ9hTl8RTDUhrV4KM2mFozHxWexum8Ic5S
