93EXCivic
93EXCivic MegaDork
8/22/21 10:05 p.m.
Ok so I am about to start building a new garage. It is going to be a 24x40 and I am going to add an interior wall at the back 10ft to have a gym and office in the garage. See photo below.
Is the best way to do this going to be be two mini-splits?
Will just having no door be enough to keep the office cool? Or should add I add pass through vents in the wall or something?
stuart in mn
stuart in mn MegaDork
8/22/21 10:21 p.m.
You're in Alabama?  A/C requirements there are going to be pretty rigorous.
You really should do an HVAC load calculation to determine what is needed.  There are a number of online calculators, you just plug in the needed values (building dimensions, amount of insulation, local temperatures, etc.) and it spits out a number.  They aren't necessarily all created equal so it's a good idea to run the numbers through several of them to make sure you get a consensus.
93EXCivic
93EXCivic MegaDork
8/23/21 9:38 a.m.
In reply to stuart in mn :
Cool. Thanks. I'll do that but do I run it as two seperate units, one for the back and one for main garage area.
grover
grover GRM+ Memberand Dork
8/23/21 8:54 p.m.
Dual or even tri split ductless could run off of a single outdoor unit.
93EXCivic
93EXCivic MegaDork
8/23/21 9:02 p.m.
Cool I didn't know those existed.
A1MKOFxiqdkfbQEy4O8xRgpR94RkfiZ82eZ3o3XKxP18UjhjbCBsrnsV4ddlvGUc
