Wally
10/28/11 1:21 p.m.
The plywood in the bottom of my bay window is wet and has water seeping up through it from the outside. Is there any way to replace this piece of wood or do I have to replace the whole window?
ThePhranc
ThePhranc Reader
10/28/11 1:21 p.m.
Sure.... just needs a lot of work.
nderwater
nderwater SuperDork
10/28/11 1:28 p.m.
Anything can be fixed with enough time and money ;)
Where is the source of the water intrusion?
Wally
10/28/11 1:31 p.m.
The bottom of the wood was left unfinished and with the never ending rain it seems to have collected in a piece of trim and been absorbed by the wood.
cwh
cwh SuperDork
10/28/11 1:34 p.m.
Get it REAL dry, apply fiberglass?
Toyman01
Toyman01 GRM+ Memberand SuperDork
10/28/11 2:00 p.m.
Yes it can be fixed. I have replaced the sills in four windows in the last year. Cut out the old and replace. It's not real hard, just time consuming. With that setup, you probably need to support the windows just in case.
914Driver SuperDork
10/28/11 3:28 p.m.
Find the source first.
jhaas
jhaas Reader
10/28/11 3:35 p.m.
look in the first image where there is sprayfoam. that could be directing the water onto the trim/flashing at the bottom of the window, and into the ply wood.
however...look at the 'sweat' on the inside of your window...thats the problem
SVreX
SVreX SuperDork
10/28/11 3:35 p.m.
That doesn't look like a wicking problem from a missing piece of trim. It looks like a pretty serious condensation problem on the inside.
The mildew stain is equidistant from the ends and the edge. If it was wicking, it would be more significant at the end grain. The window jamb at the side is wicking. The window seat is damp from direct contact, I believe.
Make sure you find the source.
EastCoastMojo
EastCoastMojo GRM+ Memberand SuperDork
10/28/11 3:36 p.m.
There's a lot of condensation on the left window and frame. Is it possible the window is the problem?
patgizz
patgizz GRM+ Memberand SuperDork
10/28/11 9:05 p.m.
EastCoastMojo wrote: There's a lot of condensation on the left window and frame. Is it possible the window is the problem?
without being there i'd bet the window itself is incorrectly installed and is now trash and could be leading to mold inside the wall around it. i remove improperly installed bay and bow windows all the time.
y7Hj1RsdNwyz470o36ush7jHimI9DD62uTseuw8CGPZYNmiXCpb1DcWHuj0gTupB
