mattmacklind wrote:Jumper K. Balls wrote:Sometimes you just gotta do what you gotta do.
He probably got himself off of the side of the road. It's not an ideal fix, but it probably worked OK for a while.
Oh no, you misunderstand. This was off of a "how to convert to an alternator" portion of a website who's owner proclaims to be a "guru" of the particular model.
I appreciate a good bodge more than most. My time in industrial maintenance taught me the simple beauty of an emergency repair, it also taught me that there is nothing more permanent than a temporary fix so the bodge better be good, but that alternator mount?
It is an MG so its going to fail no matter what.
You should just use allthread and then you only need 2 or 3 nuts. (you can leave the other 7 of your motor mount nuts attached).
rcutclif wrote:mattmacklind wrote:You should just use allthread and then you only need 2 or 3 nuts. (you can leave the other 7 of your motor mount nuts attached).Jumper K. Balls wrote:Sometimes you just gotta do what you gotta do.
Make the rear bracket longer, to lose those two nuts, cut a piece of tube for the middle stack, and you have a perfectly good mount.
Jumper K. Balls wrote: Oh no, you misunderstand. This was off of a "how to convert to an alternator" portion of a website who's owner proclaims to be a "guru" of the particular model. I appreciate a good bodge more than most. My time in industrial maintenance taught me the simple beauty of an emergency repair, it also taught me that there is nothing more permanent than a temporary fix so the bodge better be good, but that alternator mount?
The rest of the story:
For the prototype setup I used a hand full of 3/8" hex nuts which slip right over the 5/16" rod. As fate would have it, 3 nuts = 1 inch, and the center space was very close to 2", so half a dozen hex nuts did the trick. Two more hex nuts behind nicely made up the space to the rear bracket. The rear bracket also has slightly slotted mounting holes (see larger picture with loose bolts) so the bracket can float a bit and the two hex nuts are close enough.
As a matter of expediency I cut the rod to length and threaded both ends 5/16-24 UNF. The back end got two hex nuts jammed together to make a bolt head, which was quicker than welding one nut in place. The front end got a steel flat washer to protect the aluminum ear on the alternator, plus a lock washer and hex nut. Original bolt for this alternator was 10mm, so the mounting holes are a bit larger than the 5/16" rod. Just push the unit gently toward the engine block to square it up while tightening the long bolt, and it makes a very rigid attachment. I will consider later if I might replace the long rod with two shorter bolts to eliminate fiddling with the half dozen hex nuts in the middle, or maybe make a tube spacer or two for neatness.
Three months later I had the radiator out (for an unrelated reason). With a little extra time available ...I also made a pair of tube spacers to replace the eight large hex nuts on the main pivot mounting bolt.
Streetwiseguy wrote:rcutclif wrote:Make the rear bracket longer, to lose those two nuts, cut a piece of tube for the middle stack, and you have a perfectly good mount.mattmacklind wrote:You should just use allthread and then you only need 2 or 3 nuts. (you can leave the other 7 of your motor mount nuts attached).Jumper K. Balls wrote:Sometimes you just gotta do what you gotta do.
I thought this was MG OE, when they converted to alternators in the late 70s. At least as well done as the suspension height fix to meet bumper height rules...
nderwater wrote:
Attention to those chasing "patina" in their rat rods and VWs: this is what it really looks like. It comes from battle. You can't fake it.
Jumper K. Balls wrote: I appreciate a good bodge more than most. My time in industrial maintenance taught me the simple beauty of an emergency repair, it also taught me that there is nothing more permanent than a temporary fix so the bodge better be good, but that alternator mount?
As another former/current industrial maintenance person, this makes me wish I'd taken more photos of some of the bodge I've seen or had a hand in. It would be a whole thread of its own.
We had one millwright that you didn't want anywhere near a planned job. But when we were in the ditch and looking for the shortest way out, this was the guy to have around. He invented bodge.
Knurled wrote:nderwater wrote:(calmly) Details please.
At first I thought it was Autokonexion (see below) but now I'm not so sure.
