914Driver wrote:
What is this? I have a serious want.
NOHOME wrote:914Driver wrote:What is this? I have a serious want.
I think it's a White.....saw one in a local yard a few years ago that was a garbage truck.
Knurled wrote:oldtin wrote:How is that even supposed to articulate?
Just fine I'm sure. The blue piece at the bottom of the shock is a rocker, notice sway bar attached to the inside of the rocker. The shock was mounted high because it would be hard to reach the pedals if the shock was inboard.
I'm more worried about the spindle this machine must be very light and low powered, and not offroad (limited travel suspension).
Yeah, it's an early 1950s White cab over. Local guy built one, says it was a PITA because of the tilting cab.
Bravenrace's crew cab dually got me looking around.
Streetwiseguy wrote:mthomson22 wrote:I don't know what that is, but I don't like it at all.
Really? I think it's wayyyy cooler than the Deuce right below it. Good lines, something original. I like it, a lot, actually.
bentwrench wrote:Knurled wrote:Just fine I'm sure. The blue piece at the bottom of the shock is a rocker, notice sway bar attached to the inside of the rocker. The shock was mounted high because it would be hard to reach the pedals if the shock was inboard. I'm more worried about the spindle this machine must be very light and low powered, and not offroad (limited travel suspension).oldtin wrote:How is that even supposed to articulate?
I suspect the concern Knurled has is that the ends of the control arms don't look like they have ball joints where they meet the knuckle. At least that was my confusion when I looked it over.
Related:
Duke wrote: Really? I think it's *wayyyy* cooler than the Deuce right below it. Good lines, something original. I like it, a lot, actually.
That wasn't a Deuce.
Will wrote:Duke wrote: Really? I think it's *wayyyy* cooler than the Deuce right below it. Good lines, something original. I like it, a lot, actually.That wasn't a Deuce.
Well, OK. It was Deuce-like. Or maybe it was above it. I didn't go back to check.
