1 ... 3009 3010 3011 3012 3013 ... 4766
WildScotsRacing
WildScotsRacing Reader
2/5/16 10:23 p.m.
Appleseed wrote:
NOHOME wrote: Duke MegaDork: 223 lb= 101kg 556 kg = 1225 lb. Which one is it? Or am I missing a joke here?
Public Safety Announcement: All AR shooters please note; the 5.56 and the .223 are NOT, in fact, identical. The 5.56 has a slightly longer neck, thicker case walls near the head, and creates notably higher chamber pressures for the same weight of charge. DO NOT FIRE 5.56 ammo in a .223 chamber. You may, however safely fire .223 in a 5.56 chamber, just with a slight loss of precision and wider velocity spread, since the .223 case will fire-form to the 5.56 chamber. That is all.
2/6/16 7:48 a.m.
ncjay
ncjay Dork
2/6/16 8:03 a.m.
It's someone's job to keep that clean and shiny. Good thing it's not me.
ncjay
ncjay Dork
2/6/16 8:04 a.m.
NGTD
NGTD UltraDork
2/6/16 8:14 a.m.
This is what happens when the rules say you can only have 4 cylinders and you really, really want 8!
914Driver wrote:
Flight Service
Flight Service MegaDork
2/6/16 8:26 a.m.
NGTD wrote: This is what happens when the rules say you can only have 4 cylinders and you really, really want 8!
914Driver wrote:
Honda NR engine set up
Honda can do cool stuff when they aren't admiring Toyota's beige.
Flight Service
2/6/16 8:32 a.m.
So what you are saying is for a apocalypse weapon the 5.56 is a better choice of chamber because it gives you the choice of two different ammos instead of one....kind of like the .308 vs the 7.62
Flight Service
2/6/16 8:42 a.m.
Flight Service
2/6/16 8:47 a.m.
etifosi
etifosi Dork
2/6/16 10:51 a.m.
Grtechguy
Grtechguy MegaDork
2/6/16 11:35 a.m.
2/6/16 12:57 p.m.
2/6/16 12:58 p.m.
2/6/16 1:01 p.m.
Model B pickup, wtf not?
Knurled
2/6/16 1:02 p.m.
914Driver wrote:
I still want to know how they bored the cylinders.
Or calculated the piston skirts' geometry.
Or machined/sized the rings. And are the gaps at the end or in the straight span? How do they maintain seal when they expand from heat?
I note with interest, on that last item, that the oil control rings are missing from that display.
Flight Service
2/6/16 3:40 p.m.
Knurled wrote:
914Driver wrote:
I still want to know how they bored the cylinders. Or calculated the piston skirts' geometry. Or machined/sized the rings. And are the gaps at the end or in the straight span? How do they maintain seal when they expand from heat? I note with interest, on that last item, that the oil control rings are missing from that display.
The bore and hone isn't an issue with a CNC. But they also started building this in 1979.
The Oval Piston Engine.
bentwrench
bentwrench Dork
2/6/16 4:08 p.m.
914Driver wrote:
Pardon me,
Do you have any Grey Poupon?
ncjay
ncjay Dork
2/6/16 4:22 p.m.
Part of my brain really wants to hate this, but shorten the stacks (or delete altogether), lower it a few, and it would make a great race car hauler.
Streetwiseguy PowerDork
2/6/16 4:48 p.m.
Knurled wrote:
All very good questions, and also questions that Honda never really found the correct answers to. Also, why we don't see any oval piston race engines anymore.
2/6/16 6:37 p.m.
Toyman01
2/6/16 6:38 p.m.
Probably a repost but worth a repeat.
ncjay
ncjay Dork
2/7/16 3:47 a.m.
Grtechguy
Grtechguy MegaDork
2/7/16 6:45 a.m.
Donebrokeit
Donebrokeit Dork
2/7/16 1:56 p.m.
Flight Service
2/7/16 3:54 p.m.
fgT6yRLynpXOefAyV6v1Jhk5CVzbE2ELoQ2eA46fx4UuciRdGnvJrDDIHqSan08X
