1 ... 3110 3111 3112 3113 3114 ... 4751
ultraclyde
ultraclyde UberDork
4/12/16 8:56 a.m.
EvanR wrote: How to change a timing belt without losing valve timing: Cut the existing belt lengthwise, leaving half of it on the pulleys. Add new belt to pulleys. Cut the old half-a-belt off.
My first thought was that this is a genius method. But then I thought about how hard it would be to cut that existing belt. Is there a secret method to actually cutting the belt? Idle the engine while carefully applying a sharp knife?
IndyJoe
IndyJoe HalfDork
4/12/16 8:56 a.m.
IndyJoe
IndyJoe HalfDork
4/12/16 9:00 a.m.
IndyJoe
IndyJoe HalfDork
4/12/16 9:01 a.m.
BlueInGreen44
BlueInGreen44 Dork
4/12/16 9:03 a.m.
BlueInGreen44
BlueInGreen44 Dork
4/12/16 9:06 a.m.
IndyJoe
IndyJoe HalfDork
4/12/16 9:08 a.m.
BlueInGreen44
BlueInGreen44 Dork
4/12/16 9:12 a.m.
4/12/16 9:14 a.m.
It's the perfect example of how to take a straightforward job and make it more difficult, because that's what you read on a forum. They seem to specialize in coming up with half-assed, oddball ways to avoid using the factory method. Seriously, the number of extra steps I've seen people come up with on Miata forums to ensure and check proper alignment. Counting teeth, cutting belts, marking random things... all while ignoring the one factory step that gives you a 100% answer every time.
Amateurs leading amateurs in fear.
johnnie
johnnie New Reader
4/12/16 9:38 a.m.
IndyJoe
IndyJoe HalfDork
4/12/16 9:55 a.m.
IndyJoe
IndyJoe HalfDork
4/12/16 9:57 a.m.
IndyJoe
IndyJoe HalfDork
4/12/16 10:00 a.m.
etifosi
etifosi Dork
4/12/16 10:13 a.m.
etifosi
etifosi Dork
4/12/16 10:17 a.m.
etifosi
etifosi Dork
4/12/16 10:18 a.m.
etifosi
etifosi Dork
4/12/16 10:18 a.m.
etifosi
etifosi Dork
4/12/16 10:19 a.m.
etifosi
etifosi Dork
4/12/16 10:19 a.m.
etifosi
etifosi Dork
4/12/16 10:20 a.m.
NOHOME
NOHOME PowerDork
4/12/16 11:18 a.m.
It's the perfect example of how to take a straightforward job and make it more difficult, because that's what you read on a forum. They seem to specialize in coming up with half-assed, oddball ways to avoid using the factory method. Seriously, the number of extra steps I've seen people come up with on Miata forums to ensure and check proper alignment. Counting teeth, cutting belts, marking random things... all while ignoring the one factory step that gives you a 100% answer every time. Amateurs leading amateurs in fear.
Went down the same thought process. Keith also knows the only real answer to this game:
I don't even own a Miata, and I want one because of the elegance of the design.
Happy Carmore
Happy Carmore MegaDork
4/12/16 11:28 a.m.
Went down the same thought process. Keith also knows the only real answer to this game: I don't even own a Miata, and I want one because of the elegance of the design.
I want one because it holds the cams, is a key ring and opens beers.
Happy Carmore
4/12/16 11:30 a.m.
Happy Carmore
4/12/16 11:32 a.m.
Spoken like a true GRM cyclist.
Happy Carmore
4/12/16 11:33 a.m.
blyKBSlgU22x67xmGslsozVlrhId8FpSmU0EtnPValGKQvdvTI0FQYjvlfvjOHrO
