1 ... 3442 3443 3444 3445 3446 ... 4749
Wall-e
Wall-e GRM+ Memberand MegaDork
6/8/17 6:09 a.m.
Wall-e
6/8/17 6:09 a.m.
Wall-e
6/8/17 6:50 a.m.
We went to Car Night at Bear Mountain yesterday. The turn out was a bit small but there was a little of everything.
A 911, AMC, and VAZ:
Wall-e
6/8/17 6:51 a.m.
An over the top 80s style showcar
Wall-e
6/8/17 6:54 a.m.
Chadeux
Chadeux Dork
6/8/17 6:56 a.m.
HappyAndy
HappyAndy PowerDork
6/8/17 7:03 a.m.
RevRico wrote:
I once had to remove a Mercedes wheel with a sawzall. 5 of 5 extended wheel bolts did this: I didn't know about the hole-saw trick until after the wheel was all chopped up. In the end the wheel is still trash even with the hole-saw.
Wall-e
6/8/17 7:14 a.m.
6/8/17 7:15 a.m.
Motorcycle parking?
Indy-Guy
Indy-Guy SuperDork
6/8/17 7:46 a.m.
Chadeux wrote:
Awesome. This is one of the Coolest things I've seen in a LONG time.
More info for those interested
4cylndrfury
4cylndrfury MegaDork
6/8/17 9:16 a.m.
Wall-e
6/8/17 12:56 p.m.
Wall-e
6/8/17 12:57 p.m.
Streetwiseguy UltimaDork
6/8/17 1:34 p.m.
HappyAndy wrote:
Todays tech tip:
Depending on the quality of drill bit you have available, and the hardness of the studs, you can drill the stud out of the middle of the nut, or drill the hex and taper off the bolt. The toughest part is getting through the hardened head of the locking nut, but it will usually shatter if you work it hard enough.
4cylndrfury
6/8/17 1:38 p.m.
Wall-e wrote:
I call shenanigans. Based on the bold 5 in the folded bill (in the bottom right once unfolded), and on the scalloping at the border around each 5, this is an example of the back of the bill below. The area above the memorial is essentially blank, and there is nothing that extends below that border in the corner. As much as I love pancakes, I think a flat earth truther posted this...
FlightService
FlightService MegaDork
6/8/17 1:52 p.m.
4cylndrfury wrote:
I wonder if that is how you move furniture around?
Wall-e
6/8/17 2:15 p.m.
RevRico wrote:
If you take off all the lug nuts except the locks, and get a good sized helper you can shove the car side to side until the studs with the locks snap off. Two big guys and some practice can have the four tires off in a couple minutes.
FlightService
6/8/17 5:42 p.m.
In reply to Wall-e:
akamcfly
akamcfly Dork
6/8/17 5:55 p.m.
BlueInGreen44
BlueInGreen44 SuperDork
6/8/17 8:28 p.m.
Chadeux wrote:
Ha. I came here to post that pic. It's pretty cool and I like the backstory behind the build.
Knurled
6/8/17 9:30 p.m.
sesto elemento wrote: Rotfl at toyota, vw and porsche being "tied" in quality.
I fix enough crappy Toyota E36 of the M3 variety that I find the idea of Toyota "quality" to be laughable. Unless the quality is middling.
6/9/17 12:38 a.m.
4cylndrfury wrote:
What an I not seeing here?
Toyman01
6/9/17 5:51 a.m.
Appleseed wrote:
The knucklehead that plugged his mouse into his phone charger.
6/9/17 6:39 a.m.
6/9/17 6:40 a.m.
zR5MRDoENrLfyOorGdvwExIYyW8sSKlXE1ZksxckR1r15yMlFDmtsQTMiYeZpXKk
