1 ... 3481 3482 3483 3484 3485 ... 4777
4cylndrfury
4cylndrfury MegaDork
8/17/17 7:54 a.m.
4cylndrfury
8/17/17 7:57 a.m.
carguy123
carguy123 UltimaDork
8/17/17 8:52 a.m.
A Studebaker from Scandinavia
Grtechguy
Grtechguy MegaDork
8/17/17 10:02 a.m.
Think about it....
RossD
RossD MegaDork
8/17/17 10:10 a.m.
In reply to Grtechguy:
aircooled
aircooled MegaDork
8/17/17 11:06 a.m.
Knurled
8/17/17 4:51 p.m.
Indy-Guy wrote: But why the spark plugs and wires on the right hand side?
V8 distributor. When you cut power to the coil, you need to give that energy somewhere to go.
I've seen them where the four extraneous plugs were threaded into the bellhousing, too.
Knurled
8/17/17 4:52 p.m.
FlightService wrote: Have we lost our love for the Mercuiser 1/2 460 Ford with the Chevy bolt pattern? Now with the availability for much better lighter heads. You could have a 4.0 L 4 cylinder with the proper crank and pistons! Now here is you a NA porshe 944 swap.
Paging iadr.
Sparkydog
Sparkydog New Reader
8/17/17 5:02 p.m.
In reply to aircooled:
Chadeux
Chadeux Dork
8/17/17 8:22 p.m.
In reply to iadr:
Ok now I'm curious.
Hot link not related.
carguy123
8/17/17 8:23 p.m.
Having shop space problems and it's too expensive to build a shop?
kazoospec
kazoospec SuperDork
8/17/17 8:42 p.m.
8/17/17 8:58 p.m.
Chadeux
Chadeux Dork
8/18/17 12:28 a.m.
8/18/17 5:59 a.m.
8/18/17 6:04 a.m.
AWSX1686
AWSX1686 GRM+ Memberand HalfDork
8/18/17 7:10 a.m.
carguy123 wrote: Having shop space problems and it's too expensive to build a shop?
I've always liked these. Any more details on this particular setup?
Obligatory, and cool:
Indy-Guy
Indy-Guy SuperDork
8/18/17 8:20 a.m.
4cylndrfury
8/18/17 8:26 a.m.
ncjay
ncjay SuperDork
8/18/17 10:46 a.m.
RossD
RossD MegaDork
8/18/17 12:38 p.m.
GRMers are the BEST! Thanks Jumper K Balls!
tuna55
tuna55 MegaDork
8/18/17 12:55 p.m.
V8 distributor. When you cut power to the coil, you need to give that energy somewhere to go. I've seen them where the four extraneous plugs were threaded into the bellhousing, too.
Why? If the distributor has no wires, how will the distributor know it is not a I4? The rotor will hit the terminal, nothing will happen, and it will move on.
Robbie
Robbie UberDork
8/18/17 1:40 p.m.
In reply to tuna55:
You're still going to have a giant spark coming through the rotor and cap post because the points will still open at the false plug positions (I guess you could grind them off). At least if you ground them you wont be blowing your ignition system with a big back spark between every real spark plug event.
8/18/17 2:14 p.m.
Because that crap is really hard on the coil.
carguy123
8/18/17 2:38 p.m.
More container shops
ABqPDPi63xMpU1SrHU0WqvXwEss1xfnGTy5FpuwFZTKYdwvbzhHfFY3MPw4t6Vvv
