1 ... 3710 3711 3712 3713 3714 ... 4774
slefain
slefain PowerDork
12/4/18 9:23 a.m.
eastsideTim said:
slefain said:
WTF GM, seriously?
The bros will love it.  Just needs a lift, bigger tires, and a light bar.
Or the perfect truck for Jake Tucker.
Adrian_Thompson
Adrian_Thompson MegaDork
12/4/18 9:31 a.m.
slefain said:
WTF GM, seriously?
As an employee of Ford Motor Co I am absolutely delighted to see this!
NickD UberDork
12/4/18 9:54 a.m.
Adrian_Thompson said:
slefain said:
WTF GM, seriously?
Because the current Ford Super Duty aren't hideous or anything
NickD UberDork
12/4/18 9:55 a.m.
This isn't even my final form!
Introducing the 2020 Chebrolet Silverado Z71 All-Terrain Altitude High-Country Trail Boss Alpha + Omega Remix
AdventurePiggy
AdventurePiggy New Reader
12/4/18 10:03 a.m.
They were trying to recreate this, right?
Toyman01
12/4/18 10:12 a.m.
slefain said:
WTF GM, seriously?
Are Ford and Chevy in a contest to see who can make the ugliest truck?
Chevy is now winning. I hate to see what Ford comes up with to replace their brackets. [o====o]
Edit to add HL
kazoospec
kazoospec UltraDork
12/4/18 10:15 a.m.
Meanwhile, at GRM HQ:
"Don't feel bad rookie, I remember when the press shots of the Aztek came off the wire.  No shame in it."
NickD UberDork
12/4/18 10:18 a.m.
Toyman01 said:
slefain said:
WTF GM, seriously?
Edit to add HL
Meanwhile over at FCA "We're going to put the Demon motor in the Ram 3500, because studies find a large amount of customers want to be able to run a 12-second e.t while towing a 10000lb trailer"
Spoolpigeon
Spoolpigeon PowerDork
12/4/18 11:21 a.m.
Sparkydog
Sparkydog Reader
12/4/18 11:27 a.m.
In reply to kazoospec :
You nailed it! I'm convinced the Aztec "design" team must still be at large and must be considered dangerous. They might have moved to Ford and did the last 2 Mustang hoods/noses. Then moved on to Ford pickup front wall of shame, now they have infected GM again.
stanger_missle
stanger_missle GRM+ Memberand SuperDork
12/4/18 11:49 a.m.
slefain said:
WTF GM, seriously?
I thought this was a joke or something until I got to work and surfed the online auto rags. Wow. Just wow.
Someone over at J-nik created this:
Truuuuuuuuuuukkkkkdoooooooor!
Toyman01
12/4/18 12:10 p.m.
Given a choice between the three, I would have to seriously consider the Aztek. At least a little effort makes them less painful to look at.
barefootskater
barefootskater HalfDork
12/4/18 1:31 p.m.
Toyman01 said:
slefain said:
WTF GM, seriously?
Edit to add HL
No. Chevy still isn't winning, but they are a close second. The Titan is still king of ugly:
Image result for nissan titan
12/4/18 1:45 p.m.
slefain said:
WTF GM, seriously?
The Ford was awful until that Chevy raised the bar by a few feet... now it looks downright acceptable.  That Chevy looks like it got beat with the ugly stick:
Robbie
Robbie GRM+ Memberand UltimaDork
12/4/18 3:23 p.m.
To make that work, I think  you need wheels about 26-28 inches in diameter.
Doc Brown
Doc Brown Dork
12/4/18 6:18 p.m.
DeadSkunk said:
A Chevy LS engine is about 29" tall, add in 10" of ground clearance and you're at 39". WTF is the rest of that useless height for. I'll bet a shorter driver in that thing won't be able to see my Miata over the nose of the hood at a stop light.
Looks like a lot of extra space....
RevRico
RevRico GRM+ Memberand UberDork
12/4/18 6:25 p.m.
In reply to Doc Brown :
 why do I feel like a even with all that space there still wouldn't be room to work in l under the hood?
Toyman01
12/4/18 7:29 p.m.
That's probably why the back doors don't work.
Don't care, I'd still drive it.
Donebrokeit
Donebrokeit SuperDork
12/4/18 7:42 p.m.
Donebrokeit
12/4/18 7:43 p.m.
12/4/18 8:11 p.m.
Ford should co-opt some other name, because this is the true Super Duty, and the only one worth recognition.
12/4/18 9:24 p.m.
In reply to Appleseed :
8-lug wheels on a sedan FTMFW.
Scrom
Scrom New Reader
12/4/18 10:38 p.m.
Donebrokeit said:
I’m curious what those Lancias were doing in the Tacoma Dome? Those neons were so distinct and awesome!
Edit: I just looked closer and it fairly clearly says Olympus Rally above the numbers.
Wally
Wally GRM+ Memberand MegaDork
12/4/18 11:44 p.m.
The 70s were a hell of a time.
STM317
STM317 SuperDork
12/5/18 2:42 a.m.
They're not designed for gas engines. They're designed around the larger diesels. This is what a 2017 Duramax looks like:
It's also basically as capable as a medium duty truck from a decade ago. Towing 30,000lbs with a warranty requires a lot of cooling capacity, which requires a lot of frontal area:
s8bpKTLPbVY1vqFtrbR6OuJFIZdbT3CYWLofprgqh7Gq0Gkxv0DT5odZfqOaGcVY
