1 ... 4240 4241 4242 4243 4244 ... 4749
pinchvalve (Forum Supporter)
pinchvalve (Forum Supporter) GRM+ Memberand MegaDork
12/2/20 10:43 a.m.
That's it? 4242?
ultraclyde (Forum Supporter)
ultraclyde (Forum Supporter) UltimaDork
12/2/20 10:51 a.m.
A cool description of the recovery of the Golden Ray, with lots of automotive carnage photos:
https://jalopnik.com/a-chain-just-cut-through-a-capsized-cargo-ship-filled-w-1845784581
12/2/20 11:22 a.m.
THAT'S a bowl !!
slantvaliant (Forum Supporter)
slantvaliant (Forum Supporter) UltraDork
12/2/20 11:28 a.m.
In reply to ultraclyde (Forum Supporter) :
Now THIS is stuck in my head.
12/2/20 12:27 p.m.
12/2/20 12:48 p.m.
Reminds me of the wreck of the Tricolore
12/2/20 2:23 p.m.
12/2/20 2:42 p.m.
Brilliant !!
1SlowVW
1SlowVW HalfDork
12/2/20 4:12 p.m.
Peabody
Peabody UltimaDork
12/2/20 4:15 p.m.
914Driver said:
Somebody actually did that to me about 20 years ago, though he just moved it around the back of the building
Cost the company $1100 and the guy lost his job
johndej
johndej Dork
12/2/20 6:07 p.m.
David Tracy is great and would fit right in here.
Pic unrelated
11GTCS
11GTCS HalfDork
12/2/20 6:22 p.m.
pinchvalve (Forum Supporter) said:
That's it? 4242?
Well played sir, well played.  Pic related
12/2/20 7:59 p.m.
preach
preach GRM+ Memberand Reader
12/2/20 11:41 p.m.
42=Miata?
The Lion's Back in Moab, UT. When I did the run there was a full size truck wedged in the right of this pic after it had fallen off the spine.
12/3/20 8:01 a.m.
12/3/20 8:08 a.m.
slefain
slefain PowerDork
12/3/20 8:59 a.m.
12/3/20 9:31 a.m.
12/3/20 9:33 a.m.
preach said:
42=Miata?
I remember this one from years ago. =~ (
12/3/20 9:55 a.m.
12/3/20 11:50 a.m.
OK, we've all seen a lot of these literal mashups, but W the actual B:
nocones
nocones GRM+ Memberand UltraDork
12/3/20 2:35 p.m.
Everynow and then I feel bad about the damage to the planet I cause by wastefully scrapping old bolts and small pieces of metal.    Then I see this and think..  We cool Bro.
eastsideTim
eastsideTim PowerDork
12/3/20 2:50 p.m.
Maybe a cheap way of “fixing” a rollover in the Suburban?
APEowner
APEowner GRM+ Memberand Dork
12/3/20 3:01 p.m.
914Driver said:
When I worked as a Ford tech in the '80s I had a lift like this in one of my bays.  It was pretty sketchy.  Each post is controlled indipendently and they went up and down at different rates than each other depending on how much wieght was on each end, how much air was in the compressor and which way a particular butterfly in Milasia was flying (or something like that.)  Out of frame to the right of the picture the cover plate has notches along one side.  If you stick a steel bar through the notch and into a hole in the floor you can pry the top plate and the whole forward post assembly back and forth to accomodate different wheelbase vehicles.  I have no idea what the support mechanism under the plate looks like that allowes you to do that.  I was afraid to look.  There was also no visable mechanical safety to stop the lift from dropping if the hydro/pneumatic system gave out.  I told myself that there was a clever inertia based mechanical system hidden under the cover plate.
Slightly related hot link
DeadSkunk  (Warren)
DeadSkunk (Warren) PowerDork
12/3/20 5:01 p.m.
See the source image
These young ladies are all grown up now, but this photo has been seen on "The Ellen Degeneres Show', "The Graham Norton Show" in Great Britain, and has even been used in an Australian ad of some nature. They are my twin nieces and this is a good example of how shared stuff spreads on the world wide web.
az9mVXkFuvRJd0hTiNbYVJLcIt7OACv932S2Elq24ieRHXeWEgxbgOWsLpuB5OoZ
