RealMiniDriver
RealMiniDriver Dork
11/12/11 10:04 a.m.
Wife Camaro has blown speakers in the doors. They are component (?) type that have four wires going to each one. I don't want to spend a ton of money replacing them, so can I join the positive from tweeter and mid and negative from tweeter and mid to use generic two-connector speakers?
fast_eddie_72
fast_eddie_72 SuperDork
11/12/11 10:51 a.m.
Are these factory or after market? Any component speakers I've seen include a crossover that's typically mounted in the door. If you follow the four wires back a bit you may find a box that has a the normal speaker wire going into it.
But I'm guessing a bit here.
RealMiniDriver
RealMiniDriver Dork
11/12/11 10:56 a.m.
They are factory. I'll check further down the line for a box. Thanks, eddie
RealMiniDriver
RealMiniDriver Dork
11/12/11 12:03 p.m.
That's a big bummer. Factory amp, running four wires to the door. No crossover in the door.
fast_eddie_72
11/12/11 5:05 p.m.
Ug. Well, if you can find speakers that you can look at- a lot of them have two sets of wires leaving the terminals. So you could modify them.
What's "blown" exactly. No sound at all? Woofers blown but tweeters work? There's a few ways to skin that cat without spending a ton.
xFactor
xFactor New Reader
11/12/11 6:33 p.m.
Factory multichannel. Figure out which pair is the high pass and low-pass with a test speaker. I have modded Alpine Type-s co-axes in the past by unsoldering the tweeter wires off of the terminals on the frame and extending them with quick disconnects going to the high pass channel. Wire up the woofer to the low-pass as usual. I'm sure you can do the same with other brands.
later, matt
Nitroracer
Nitroracer SuperDork
11/12/11 8:36 p.m.
You probably have the same stock sound system my 98' Camaro has. The previous owner ended up running new speaker wires through the car to an aftermarket head unit. Its a mess.
Derick Freese
Derick Freese Dork
11/12/11 9:45 p.m.
What about putting component speakers in the car? I picked up some Infinity Reference component speakers for $50 on another forum one time, and deals like that are common.
fast_eddie_72
11/12/11 9:47 p.m.
What size are the speakers? If it's a bi-amped system with the crossover happening before the amp, you just need to find appropriate size drivers. If they're normal sizes, shouldn't be too hard. There are inexpensive component systems you could use if you just want some sound. Just don't use the included crossovers. This type thing:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=267-7172
Or if the tweeters are working and you just need woofers, then just find some decent woofers. Maybe something like this:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-305
Or this:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=299-155
That Focal is probably a decent driver. Doesn't go very low, but Focal is usually pretty good stuff. I've had good luck with the Dayton stuff. There's all kinds of woofers for $10 or so. A little more and you can probably get something as good or better than factory.
A tweeter like this would probably fit a lot of factory locations.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=275-025
Lots of ways to go.
Or run something like that Dayton with a small tweeter.
davidjs
davidjs Reader
11/13/11 5:56 a.m.
You also might want to do some searching on a dedicated stereo forum, sometimes those factory amped speakers are an odd ohmage, which will either not sound great with after market speakers, or will kill your amp sooner.
RealMiniDriver
RealMiniDriver Dork
11/13/11 5:54 p.m.
xFactor wrote: Factory multichannel. Figure out which pair is the high pass and low-pass with a test speaker. I have modded Alpine Type-s co-axes in the past by unsoldering the tweeter wires off of the terminals on the frame and extending them with quick disconnects going to the high pass channel. Wire up the woofer to the low-pass as usual. I'm sure you can do the same with other brands. later, matt
That's what I did. She'll be happy to have sound in front now.
xFactor
xFactor New Reader
11/13/11 7:59 p.m.
Good job, I've done that many times to those Camaro systems.
later, matt
LU2Nq097Z13lVqpadtV69Wxy9dqQfqu8KFCpdl2LSBwhZXf2xaQy37GzrQRx58VX
