SyntheticBlinkerFluid
10/31/14 10:27 a.m.
Well now you can stop wondering.
http://youtu.be/kx_j1ixjxac
That sound! Out of a Plastic Engine!
noddaz
noddaz GRM+ Memberand Dork
10/31/14 10:33 a.m.
I built one of these when I was a kid... Sure didn't run like that. And sure didn't run for long after I hooked a couple (maybe 3 or 4?) of batteries together to make it run faster.
SnowMongoose
SnowMongoose Dork
10/31/14 10:42 a.m.
I hadn't ever wondered that.
But am glad that someone else did!
MadScientistMatt
MadScientistMatt UberDork
10/31/14 11:59 a.m.
Looks like it has a bit of a blow-by problem with all that oil in the exhaust.
Ok, so a plastic engine block probably isn't too good for ring seal.
Curmudgeon
Curmudgeon MegaDork
10/31/14 12:13 p.m.
Dang. I'm surprised it didn't blow. I'm thinking plastic connecting rods aren't rated for 7k.
aircooled
aircooled UltimaDork
10/31/14 12:38 p.m.
They make a rotary engine model also you know....
tuna55
tuna55 UltimaDork
10/31/14 12:53 p.m.
My mind is blown to find out how much of the noise a typical internal combustion engine makes is completely unrelated to the actual combustion. Amazing
Toyman01
Toyman01 GRM+ Memberand UltimaDork
10/31/14 1:12 p.m.
Test #135? Really? Life is so boring he did 135 tests on a plastic engine?
I haven't done that many tests on a real engine.
10/31/14 1:48 p.m.
Toyman01 wrote: Test #135? Really? Life is so boring he did 135 tests on a plastic engine? I haven't done that many tests on a real engine.
I'm going to say Retired.
T.J.
T.J. PowerDork
10/31/14 1:55 p.m.
We need to figure out how to harness that guy's powers for good. His original goal was to get it up to 500 rpm, but due to "mission creep" he ended up going past 7k.
He needs to step away from the plastic engine and see if he can raise the redline of an actual car engine.
neon4891
neon4891 UltimaDork
10/31/14 2:28 p.m.
tuna55 wrote: My mind is blown to find out how much of the noise a typical internal combustion engine makes is completely unrelated to the actual combustion. Amazing
But it sounded good.
bikerbenz
bikerbenz Reader
10/31/14 3:42 p.m.
souless po
fujioko
fujioko Reader
10/31/14 4:41 p.m.
I'm torn.....It's cool that he got it to spin way past a reasonable speed... but a catastrophic failure would also have been cool to see.
Woody
Woody GRM+ Memberand MegaDork
10/31/14 8:50 p.m.
I have a half built Visible Rotary in my basement and a Smithsonian Motorworks four cylinder that's still in the box. I'm planning to build the four with my six year old this winter.
Woody
10/31/14 8:53 p.m.
Woody
10/31/14 8:55 p.m.
Kenny_McCormic
Kenny_McCormic PowerDork
10/31/14 8:57 p.m.
Intakes are a lot louder than many people think. Same goes for the valvetrain, hence hydraulic lifters being most commonly found in pushrod applications, eliminates the chatter of all the parts between the camshaft and valve stem slamming together every time a lifter hits an opening ramp. Then there's piston slap, and gear and chain noise, and the fan if equipped.
Lesley
Lesley PowerDork
11/1/14 9:13 p.m.
I built that 4-cylinder one with my nephew one Christmas...
Trans_Maro
Trans_Maro UberDork
11/1/14 11:51 p.m.
In reply to Kenny_McCormic:
I've got a 1950's British motorcycle in my fleet and I've always been surprised at how much noise the valvetrain makes.
I've had it apart, adjusted, tightened, modified, etc with no improvement. Only thing I hadn't done was split the case to look at the cams.
Other guys with the same bikes assured me that the noise was normal and their bikes were the same.
One day I got a look at a set of stock cams for this engine and holy crap... They don't set the valve down, they just plain drop it! There is almost no ramp on the closing side of the cam.
No wonder it makes noise.
Shawn
11/2/14 1:09 a.m.
In reply to Trans_Maro:
I figured out that an old Honda engine is supposed to sound like a sewing machine.
11/2/14 1:10 a.m.
In reply to Woody:
How soon till it poops out the apex seals?
Curmudgeon
Curmudgeon MegaDork
11/2/14 6:12 a.m.
Yeah, way back when I learned that if an OHC bike engine did NOT make valve train noise investigate IMMEDIATELY. Pushrod engines, typically the valve lash opens as the valvetrain wears. OHC, the wear is not as prevalent because there's fewer parts. What happens is the valve seats wear, this causes the valve to 'grow' out of the head. Since the lash is usually around .004-.006 it doesn't take much to close it, thus making the noise go away. But the quiet valves fry!
There's a lot of engineering that goes into getting rid of intake 'honk'. Somewhere or other I recall that is about 25% of the noise from the average engine, so when you see all that stupid plumbing stuck to the airbox that's what the engineers were trying to accomplish. It also explains those weird long tubes and stuff that seem to do nothing, they are resonance chambers.
Appleseed, he's gotta add boost to do that.
Knurled
11/2/14 7:03 a.m.
A lot of the cool noises we hear are intake drone, which is a good chunk of why Diesels can be so loud. The rest is combustion (not exhaust) noise ringing through the block, which is why inlines tend to be a lot louder than V engines - on a V engine half the noise disappears into the valley.
And then there's timing chain noise, which was the bane of Quad 4s and a good chunk of the reason why VW is burying the chains in the back of the engine so the noise disappears into the bellhousing...
Knurled
11/2/14 7:10 a.m.
I had a completely stock '80 RX-7. The Silent Sports Car. I probably made the car twice as loud by putting a modified carb with no choke horn on it. Removing the choke plate let a LOT more intake noise out of the carb! Sounded like the guys who put Webers on their engines, not tinny but kind of a high-pitched throatiness.
This is why, when I put the poorman's ITBs on my engine, I spent probably the first three months deliberately whacking the throttle open at low RPM so I could hear the intake bwuuuuuuuuuuugh. Reminded me a lot of the original Getaway in Stockholm when he was putzing the 911 around in that town square area. This is WHY I want to put twin Webers on my GTI.
SVreX
SVreX MegaDork
11/2/14 7:18 a.m.
Where can I get one like that?
I don't need one that revs to 7K, but I would like one that runs (circulates oil, has timing adjustment, etc.)
The only ones I am familiar with have a hand crank and rev to about 3rpms.
Any one know a better one?
I want one to teach my kids.
9MMTulvPBbfACafgwQ4CvMFNBZDXRRteuXxbyRVaJAX7G0dHsRGAejjBHbwrEv0H
