slefain
slefain PowerDork
7/9/21 10:22 a.m.
Maybe some red wine and some soft jazz. Don't discount some conversation as the night goes on. Don't spend too much time talking about yourself. Should loosen things up a bit.
Mr_Asa
Mr_Asa UberDork
7/9/21 10:29 a.m.
You know, depending on the size you could drill and tap it, then screw in an eye bolt and attach a slide-hammer to the eye-bolt?
Cchambers13
Cchambers13 New Reader
7/9/21 9:31 p.m.
Stuck rusted metal needs big heat and big hammer. OA is ideal, Mapp will get you there slowly. Favorite medium persuasion instrument is a 7-10lb mini sledge, at those impacts a screwdriver plastic handle takes some of the force spike away so a steel punch is better.
Kroil is king, PB is a distant 2nd and basically any real lubricant is better than wax in my experience. Wax just burns off at the Temps you need to really get something unstuck.
Enjoy arm day!
glueguy (Forum Supporter)
glueguy (Forum Supporter) GRM+ Memberand Dork
7/10/21 6:39 a.m.
Had not heard of wax, till I saw a post of Curtis's in the last couple years. Would have been a skeptic, except I trust the source! Have not had (or needed, fortunately) to try yet.
I too learned this trick here and it's magic. Removed exhaust studs at the manifolds on a 20 year old 285k motor without breaking a single one thanks to heat and candle wax.
chaparral
chaparral GRM+ Memberand Dork
7/12/21 9:28 a.m.
8 lb hammer, a hard steel drift of appropriate dimensions, and a well-controlled two-handed swing. Yes, this means having someone hold the drift. Yes, they can use tongs.
You will want to wear AT LEAST some beefy safety glasses and should consider a motorcycle helmet.
7/12/21 3:52 p.m.
Some Carl Heideman greatness: Freeing Rusty Fasteners With a Blow Torch
wawazat
wawazat Dork
7/12/21 4:05 p.m.
On tonight's episode of Jackass...
90mQF9jN5lRT9995c7PXRvVLypX9AnXEvpAHNth9oNsOwZHV63rrXifAkbxTjfpa
