Sultan
Sultan HalfDork
5/18/13 4:28 p.m.
Well my wife's husband is at it again! He was backing his car out of the garage and forgot that he had left a quart of gear oil behind the rear wheel. Yap it exploded! What a jerk!!
Because I am "lucky" enough to have cats I had cat litter. I put that down and got most of it yet the floor has a layer still there.
So oh wise GRM family how do I clean the rest off of the floor?
Thanks!
dean1484
dean1484 GRM+ Memberand UberDork
5/18/13 4:39 p.m.
Mop up as much as you can with disposable towels then hit it with the Dawn liquid dishwashing soap & water. Scrub rinse and repeat as needed.
Sultan
Sultan HalfDork
5/18/13 4:46 p.m.
Thanks Dean! BTW swearing a lot doesn't seem to help at all and it is hard on your throat....
grafmiata
grafmiata SuperDork
5/18/13 5:05 p.m.
Foaming oven cleaner works well sometimes.
iceracer
iceracer UberDork
5/18/13 5:58 p.m.
I often found that a second coating of oildri/cat litter will finish the job.
Just leave it there for a day or two.
Sultan
Sultan HalfDork
5/18/13 6:01 p.m.
I had good luck with Dawn yet I am sure I will need to do more tomorrow.
And oddly enough my wife doesn't seem to like the smell. Things you learn after 25 years....
SnowMongoose
SnowMongoose Reader
5/18/13 6:16 p.m.
Better on the floor than in the eyes.
fasted58
fasted58 PowerDork
5/18/13 6:27 p.m.
+1 for Dawn
oldeskewltoy
oldeskewltoy Dork
5/18/13 6:28 p.m.
brake clean and a rag should get the residue of the gear oil up
3brokenhondas
3brokenhondas New Reader
5/18/13 6:30 p.m.
Worst automotive smell ever. +3 for dawn
ultraclyde
ultraclyde Dork
5/18/13 6:43 p.m.
The only repair jobs I've ever done that caused me to throw away clothing were clutch replacement and rear-end work. That stuff's horrid.
Also, Purple Stuff degreaser works well on the last of the residue, but don't let it dry before hosing it off, and don't get it on anything you love.
JtspellS
JtspellS Dork
5/18/13 7:18 p.m.
Brakleen is your friend, then something like simple green or we have this HD stuff at work called Rizol but idk if its commercially available.
Kenny_McCormic
Kenny_McCormic UberDork
5/18/13 8:33 p.m.
Grind the kitty litter in the concrete.
Knurled
Knurled GRM+ Memberand UltraDork
5/18/13 8:50 p.m.
I have a cleaner at work called Spray Nine that WILL clean anything off of anything. Will remove gear oil from cement and/or concrete. I don't know where we get it from, though. (It smells IDENTICAL to K&N Filter Cleaner)
dean1484
5/18/13 9:02 p.m.
That stuff is the worst smelling stuff. I always seem to get it in my hair (what is left of it) when ever I am working with it. It is the equivalent of car snot. Just a dab on you and the next thing you know it is everywhere.
The brake cleaner will help to pull it out of the concrete but on those really warn summer days years from now you will still get a wiff of it every now and then.
EvanB
EvanB GRM+ Memberand PowerDork
5/18/13 9:10 p.m.
I've been testing concrete cleaners at work that seem to work pretty well.
This is similar but I haven't tested it yet so I'm not sure if it works.
http://www.amazon.com/KUTTER-OG32-Grabber-Remover-32-Ounce/dp/B002V4TIXS
5/19/13 12:46 p.m.
Kenny_McCormic wrote: Grind the kitty litter in the concrete.
This.. stand on it and grind away. Works wonders
Streetwiseguy UltraDork
5/19/13 2:59 p.m.
Sprinkle a decent coat of dry laundry detergent on the stain, then grind as with kitty litter, scoop and wash. Hot water is better.
novaderrik
novaderrik UberDork
5/19/13 3:39 p.m.
mineral spirits and a rag.
DrBoost
DrBoost PowerDork
5/19/13 3:58 p.m.
believe it or not, I use floor dry like you did to get up all I can with the broom. Then I put some more on and do The Twist and grind the floor dry into the spill. Maybe 30 seconds of this and you'll be surprised what it gets up. That part of the floor will look cleaner than the surrounding floor.
joesmith
joesmith
4/16/14 6:45 a.m.
Use the dish washing liquid,soap with a nylon brush to remove the oil stains. You can also use kerosene for the concrete floors. For more information visit website.
tuna55
tuna55 PowerDork
4/16/14 6:54 a.m.
Dad used to call it the Kitty Litter Shuffle. Put on a good song and dance in the stuff. For a while.
pilotbraden
pilotbraden SuperDork
4/16/14 9:28 a.m.
I have never used it but ReKrete is used at airports
http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_AviationConsumer_ReKrete_HangarFloorCleaner_205923-1.html
chandlerGTi
chandlerGTi SuperDork
4/16/14 9:43 a.m.
DrBoost wrote: believe it or not, I use floor dry like you did to get up all I can with the broom. Then I put some more on and do The Twist and grind the floor dry into the spill. Maybe 30 seconds of this and you'll be surprised what it gets up. That part of the floor will look cleaner than the surrounding floor.
The way to fix that one spot being cleaner is to spill the gear oil evenly over the whole floor.
4/16/14 9:54 a.m.
yes.. stand atop it and grind that stuff in. It is the only way to soak it all up
JQbWZomeOekzb4Jlmr0KeoVTicyPFnQF11bIQOqHCiPliwRYxbjnPn8L6zPGPQRe
