scardeal
scardeal Dork
10/29/12 12:06 p.m.
So, my wife has this gazelle thing that she exercises on. It's like a swing for each leg. Unfortunately, it's developed a hideous squeak that's so loud and piercing that the thing is unusable.
What sort of grease should I use to lubricate it? We bought if off craigslist, so I don't have a manual. I tried a graphite-based lubricant, and that didn't work.
10/29/12 12:07 p.m.
Is the company still in business? They might know.
failboat
failboat SuperDork
10/29/12 12:10 p.m.
just some plain old white lithium grease? i put that E36 M3 on everything.
DaveEstey
DaveEstey SuperDork
10/29/12 12:19 p.m.
failboat wrote: just some plain old white lithium grease? i put that E36 M3 on everything.
this
benzbaronDaryn
benzbaronDaryn Dork
10/29/12 12:26 p.m.
Silicone spray lube, I don't like lithium grease as it is too sticky and gooey.
1988RedT2
1988RedT2 UltraDork
10/29/12 12:28 p.m.
Pull it apart and coat everything with axle grease--it's nice and sticky and gooey!
scardeal
scardeal Dork
10/29/12 12:47 p.m.
If they don't answer my email by the end of the day, I'll pick up some lithium grease on my way home.
bravenrace
bravenrace PowerDork
10/29/12 12:51 p.m.
I use dry graphite lubricant on my universal machine, which is what the maker recommended. Does a good job and doesn't make a mess.
failboat
failboat SuperDork
10/29/12 12:53 p.m.
yea i thought about that making a mess part. I dont care if my lawnmower makes a mess. I might care if some exercise equipment dropped some grease on the carpet.
I'd still grease it up, cycle the machine a few times then wipe off some excess grease. and just keep an eye on it for a few days.
nocones
nocones GRM+ Memberand Dork
10/29/12 12:56 p.m.
I've used Bar soap with decent success on such aplications. Like rub a bar of soap on it. If it works it's way out and gets on the carpet who cares.
petegossett
petegossett GRM+ Memberand UltraDork
10/29/12 5:27 p.m.
Bacon grease, duh.
1988RedT2
1988RedT2 UltraDork
10/30/12 6:47 a.m.
petegossett wrote: Bacon grease, duh.
A great idea as long as you don't have a dog. A dog would lap at that thing until any last smell of it was gone, with the result being that the bearing surface would be entirely washed out with dog saliva.
GameboyRMH GRM+ Memberand PowerDork
10/30/12 7:53 a.m.
Lithium grease is best for metal-to-rubber squeaks. If it's metal-to-metal use axle grease.
Zomby Woof
Zomby Woof UberDork
10/30/12 11:30 a.m.
In the house I have used both vegetable oil and vaseline. No stink, no mess.
Klayfish
Klayfish Dork
10/30/12 11:37 a.m.
Zomby Woof wrote: In the house I have used both vegetable oil and vaseline. No stink, no mess.
TMI....
scardeal
scardeal Dork
10/30/12 11:50 a.m.
GameboyRMH wrote: Lithium grease is best for metal-to-rubber squeaks. If it's metal-to-metal use axle grease.
Thanks for the heads up!
wlkelley3
wlkelley3 Dork
10/30/12 8:18 p.m.
I was thinking something more ironic. Like the need for exercise equipment after cooking and eating the bacon to get the bacon grease to lube the exercise equipment. Or something like that.
But you're right about the dog thing too.
scardeal
scardeal Dork
10/31/12 9:05 a.m.
Well, I put lithium grease in there, as the manufacturer recommended. I put it in there until it was squirting out the cracks. Still squeaking.
1988RedT2
1988RedT2 UltraDork
10/31/12 9:43 a.m.
scardeal wrote: Well, I put lithium grease in there, as the manufacturer recommended. I put it in there until it was squirting out the cracks. Still squeaking.
Have you checked for a mouse?
scardeal
scardeal Dork
10/31/12 9:45 a.m.
1988RedT2 wrote: Have you checked for a mouse?
I didn't hear any clicking, and no USB port.
dculberson
dculberson SuperDork
10/31/12 3:03 p.m.
We had a nasty squeak coming from our elliptical machine. It turned out the rear bearings had worn and were grinding themselves to pieces. I disassembled it and measured the bearings, turned out McMaster had the right replacements. Had them the next day and installed them that weekend. I got oil impregnated bearings. No more squeak!
It might not be the case with your equipment, but it would be worth finding the source of the squeak in case something is worn. Replacing the bearings before they result in a damaged non-replaceable part would be good.
sleepyhead the buffalo
4/1/21 7:10 a.m.
joymelson said:
In reply to scardeal :
I will suggest you use lithium grease. It's the best for any metal equipments,[…] inclusive. I always use it for all the used gym equipment I buy before using them at all. It makes them last longer and enjoyable.
yeah, I hear it's good to improve your canoe glide too.
1988RedT2
1988RedT2 MegaDork
4/1/21 8:34 a.m.
Wow.  What a fun old thread!  I wonder if the exercise equipment in question is still in use.  Still squeaking?
MzsH2wTgZHDIg3GIko49GQvMCdx2C1YRt4DI5KcGmR2GGD558eJTQz4n1zut1fiy
