Curtis73 (Forum Supporter)
9/7/20 11:20 a.m.
I have this trusty old Craftsman bench planer.  Model 351.217580.  Like this.
See the source image
The thickness adjustment crank has a threaded shaft that goes down one side to a bevel gear set which turns a horizontal shaft to another bevel gear set to spin the threaded shaft on the other side.  The bevel gears are cast plastic and the keyway sheared off a couple of the gears.  Replacement parts are no longer made.
For a while, there was a guy on ebay who fabbed his own from steel and was selling a set of 4 for $60.  Now that ebay link shows he's selling them for $550.  Not helpful.
Anyway, the part number is 24786.00.  The goal is to find 4, otherwise I'm looking at trashing this perfectly good planer and spending $400 on a new one.  Another possibility is to find a company that makes bevel gears and try to get lucky enough to find one off the shelf that will work.
Mr_Asa
Mr_Asa Dork
9/7/20 11:30 a.m.
Print a few of these to test fit, then send them off protolabs or some other rapid manufacturing shop?
https://www.thingiverse.com/thing:3074142
9/7/20 12:05 p.m.
That one looks great, but it's a different keyway.  That one has two flat sides.  Mine uses a woodruff-type key.
9/7/20 12:08 p.m.
I thought about making a sand mold and casting some from aluminum, but that is max effort and not easily done.
OHSCrifle
OHSCrifle GRM+ Memberand SuperDork
9/7/20 12:14 p.m.
I have a similar problem with a practically new Delta bandsaw that I accidentally grabbed by the table and broke off the tilt gear. Part NLA..
That gear looks like a fairly easy part to replicate in sketchup and maybe somebody with a printer could make a couple.
Steve_Jones
Steve_Jones HalfDork
9/7/20 12:18 p.m.
Contact the ebay seller, it looks like a mistype. If you look at completed listings he sells them for $55
even on the one completed for $550 it shows them actually selling for $55
Racebrick
Racebrick New Reader
9/7/20 12:20 p.m.
If you don't have a 3d printer, this seems like a great excuse to purchase one.
Mr_Asa
Mr_Asa Dork
9/7/20 12:21 p.m.
Sand mold is hard mode.  Plaster casting is so much easier.  You do have to burn out the plastic, though so you'd need good positives.  Something you could do with a silicone mold?
This looks promising?
https://shop.sdp-si.com/catalog?cid=p271
9/7/20 9:56 p.m.
I had looked in several catalogs; McMaster, Fastenal, Grainger, et al.  Nothing close, but I'm continuing the search.  Originally, I was hoping it was all SAE.  The OD was 1.248 (sounds like inch and a quarter) and the bevel diameter was .980 (sounds like one inch), but the ID for the shaft was .390".  The closest fraction to that is 25/64.  So I switched the calipers to metric and got 25mm, 32mm, and 10mm on the nose.  I think the gear part wouldn't matter much, but there is nothing I can do about the 10mm ID.
9/7/20 9:56 p.m.
Oh.... GOOD CATCH.  Off to email him now.
Mr_Asa
Mr_Asa Dork
9/7/20 10:33 p.m.
The link I gave did have a metric beveled gear section. You should be able to look through it if you go up a level or two in the index.
Edit: https://shop.sdp-si.com/catalog/?cid=p392
https://shop.sdp-si.com/catalog/?cid=p3133
slefain
slefain PowerDork
9/8/20 8:22 a.m.
Plaster cast, then pour a new one using JB Weld. Ugly, but should work.
9/8/20 8:52 a.m.
Ebay seller got back to me.  He altered the price so no one buys any because he's out of stock.  Should have more by the end of the week.
9/8/20 2:40 p.m.
Yay.
5FxyCkXn8ob5RjDEDxD9lD9qGVo3pd3ZW6U6tGExQrMtnNBMJjjtiyudUMxDc8Gf
