akamcfly
akamcfly Dork
9/23/17 11:17 a.m.
Happens only with linens it seems (clue?)
Model is YWFW9151YW00
I have googled and the usual issue is a clogged drain filter or drain check ball. This thing is eerily clean inside the pipes. There was zero gunk anywhere (clue?)
Pump? Board?
Thanks in advance :)
bearmtnmartin
9/23/17 3:11 p.m.
drain pump has packed it in.
mrap1000
mrap1000 New Reader
9/23/17 6:12 p.m.
I had a first generation Duet washer.  There was a corrugated rubber hose between the drain connection on the drum and the pump.  The hose was molded with a square chamber in it to catch loose change and debris.  Every 18 months I would have to pull the front panel off the washer, disconnect the rubber hose from the pump and clean out all the stuff that accumulated there.
It's worth a shot....
akamcfly
akamcfly Dork
9/23/17 7:09 p.m.
Did that. There's a cap you unscrew and it's the lint trap. Clean clean clean. Then I heard there was a rubber hose that comes right off the drum with a plastic ball in it. Also clean. I will check the resistance across the pump leads now that I have a number to watch out for. Maybe tomorrow.
Thing is, it seems to only happen when it's bed sheets or when you do a second load immediately after the first one is finished. There are no strange noises from the pump either.
TVk2tiGgFncm0cVMqDbQRghkGAf2rMdjKVsglM2tYFbdQjpwJPHoxokFAAG8uDll
