ProDarwin
ProDarwin PowerDork
8/31/18 8:39 p.m.
I etched this plate.  Then I left the vinyl mask on and painted the etched areas with Rustoleum rust-converter.  Then peeled the vinyl off and the plan is to clear coat the whole thing.
The problem is there is a ton of sticker residue.  How do I get rid of this safely without destroying the paint around it?  It isn't easy to scrub, and its not a flat surface like a car.  I've tried goo gone and I'm not having much luck.
What is the melting point of this residue?  I'm wondering if I can torch it and get it to melt off without the black paint burning off?  The black doesn't need to remain perfect, but I don't want to go down to bare metal because I need the contrast when finished.
8/31/18 8:41 p.m.
Bestine rubber cement thinner.  It takes off nearly every kind of adhesive goo and scrunge, and it's amazingly benign on most plastics and other finishes.
loosecannon
loosecannon Dork
8/31/18 8:48 p.m.
Good old lighter fluid (for zippo lighters) works great but to be safe, try a little on the paint in an area you can't see
mtn
mtn MegaDork
8/31/18 8:52 p.m.
We use Ronsonal on guitars.
NOT A TA
NOT A TA Dork
8/31/18 10:12 p.m.
Wax & grease remover used for automotive finishes.
stuart in mn
stuart in mn UltimaDork
8/31/18 10:21 p.m.
3M general purpose adhesive cleaner.  Should be available at any auto parts store.
https://www.autobodytoolmart.com/3m-general-purpose-adhesive-cleaner-p-10946.aspx
aircooled
aircooled MegaDork
9/1/18 4:57 p.m.
Citric acid (those Citrus bases cleaners) and WD40 work for that.  WD40 might make it hard to clean up for paint though.
9/3/18 8:56 a.m.
These are what I use. Recently I had to remove sticker goo from painted metal and then prep the surface for a new sticker using only common household chemicals, WD40 followed with alcohol for cleanup worked well.
wvumtnbkr
9/3/18 9:13 a.m.
They make decal erasors which are like giant pencil erasers on a wheel that go on a drill.
It works well for the racecar.
clutchsmoke
clutchsmoke SuperDork
9/3/18 3:59 p.m.
In the future when removing what may be a troublesome sticker heat it with a heat gun first and then peel it off. That should take most of the adhesive with the sticker. When we recycle boxes by reusing them to ship products at work that's how we remove UPS/FedEx labels from them.
EastCoastMojo
9/3/18 4:43 p.m.
I have a citrus based degreaser called Oranj Peelz (made by Pedros) that is amazing on sticker residue and does not harm paint at all. I buy it at the local bicycle shop but amazon has it too. Other citrus degreasers may work well too, but Oranj Peelz is all I ever use for sticker gunk.
ddavidv
ddavidv UltimaDork
12/27/21 7:20 a.m.
I tried everything in my garage to remove the glue residue after cleaning decals off my old KLR motorcycle. The ONLY thing that worked effectively was the cleaner from my parts washer, and it worked great.
Jerry
Jerry PowerDork
12/27/21 8:04 a.m.
I've used WD40 on old cars but they have a smooth finish.  It's a thought if you run out of ideas.
drock25too
drock25too GRM+ Memberand Reader
12/27/21 8:06 a.m.
I removed some stickers from a helmet I bought and used rubbing alcohol to remove the residue. Worked great.
MrJoshua
MrJoshua UltimaDork
12/27/21 8:18 a.m.
I want to emphasize how strongly I agree with this. Residue that was over a year old, had been attacked with goo gone, WD40, and a plastic razor, wiped right off with a paper towel and 3M.
1xj6kxcshnihpjlgB58ISJQJl3Hh1VmSiOgNbNFcUdMjxtVWN2FNrHvsW2Rs00d2
