Mndsm
MegaDork
5/2/24 8:59 a.m.
Ok GRMers, got one from the vault for you, and since yall are generally smarter than me, I need help figuring this out and potentially prototyping it.
I need a shape. Specifically a toroid. A donut, if you will. EXCEPT, I need the cross section of the "cylinder" of the donut to be triangular. so like when you roll out a tube of dough, before you make it into a donut, and you squish that tube so it's three sided long ways. google tells me it's called a traingular prism. SO- I need a toroid made of an equilateral triangular prism joined at the ends. EXCEPT....
I need a 120* twist in it. a one third rotation in the triangle. why? I have a theory. I know how a mobius strip works, where it's technically one sided. In my head at least, this triangular toroid with the twist in it works the same way. And I want to make a continuously flowing piece of art on it that runs back into itself. Three sided. Why? Because CLEARLY I should have been a pot head, despite never having ingested a marijuana voluntarily in my life. ( I can't speak for contact highs). I could theoretically do it in clay, but I'm looking for a cleaner material. Any thoughts? Ideas?
Sounds like an application for cad and a 3d printer.
I'm sure that's possible in OnShape or other free software. At this time I can't mess with it, but maybe over the weekend???
Tinkercad is very much like sticker designs in Forza, and you're damn good at those
Done, where do I send it and what file format?
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2024/05/02/1714655886_image_mmthumb.png)
Mndsm
MegaDork
5/2/24 9:32 a.m.
Well.....E36 M3. I wasn't expecting it THAT fast. Ummmm....HM.
What format do 3d printers understand?
thomas dot larson at geemail dot com
Mndsm
MegaDork
5/2/24 9:48 a.m.
Got it.
Once again, GRM delivers.
Get me a STEP file and I will get a part to Mndsm.
Mndsm
MegaDork
5/2/24 10:10 a.m.
In reply to Slippery :
get me an email and i'll forward you what nonack has given me.
This is going too well. I'm scared now.
NOHOME
MegaDork
5/2/24 11:01 a.m.
FYI Wed o want to see this when printed cause it kinda hurt my head reading the original post.
should be en route.
Got it, will print a test part tonight.
What kind of OD/ID are you looking for?
Mndsm
MegaDork
5/2/24 11:44 a.m.
ULTIMATELY- pretty big. 15" OD- ID....that's a good question. I'm not really sure. 10-11"
At outset... IDK. Whatever you're comfortable running. I'm not entirely sure how this is going to work. EVENTUALLY I want to make a castable buck so I can mold these things and make em without having to have them printed. I get the feeling they'd sell.
Mndsm
MegaDork
5/2/24 11:46 a.m.
Just wait til you see what I want to do with it. If my theory's correct I'm gonna hurt people.
Pictures or it didn't happen.
Unrelated, I found a whole skid of triangular tubing over at the laser tube cut building. Isosceles not equilateral, 2.5 to 3" on the long side.
Mndsm
MegaDork
5/2/24 12:12 p.m.
I have to get the prototypes in hand first. It works in my head, I can't really model it on paper, and the easiest answer was go directly to 3d model. SO- here we are.
Try making a prototype out of 3 strips of poster board.
Mndsm
MegaDork
5/2/24 3:55 p.m.
In reply to GameboyRMH :
Yeah, I'm not THAT cool. realistically any prismatic polygon could be oriented in this fashion and come out this way, in theory. it's a matter of basic math, where a regular mobius is 180* or 360/2, this particular one is 360/3. it should scale indefinitely- as theoretically a circle is just 360*, a cylinder is that + length, and a toroid is just a cylinder turned back into a circle. It gets weird when you take that toroid, put it on its side, turn IT into a cylinder, and then make it into another toroid. This is also infinitely scalable.
Since it is a mobius "shape" it should be capable of being made with a single flat sheet. Nonack may be able to generate the flat pattern from his model... That could provide you a way try different sizes for the effect you want.
In reply to stafford1500 :
I'm gonna pop some tags cuz this sounds berkeleying awesome.
NOHOME
MegaDork
5/2/24 7:08 p.m.
Novel design for a poly-dimensional race slick?
Mndsm
MegaDork
5/2/24 8:28 p.m.
In reply to NOHOME :
Think of all the treads you could have.
