dimarra
dimarra Dork
3/3/10 7:29 p.m.
Does anyone have, or know of, a database of cylinder head bolt sizes? I'm trying to track down some bolts and figure that since many manufacturers require/suggest bolt replacement during head gasket changes, what I need MIGHT be sitting on local auto parts stores' shelves.
To be specific, I'm looking for 2 bolt sizes:
M10 x 180 +/-5mm (preferably 1.25 pitch but will accept 1.50)
M10 x 240 +/-5mm (preferably 1.25 pitch but will accept 1.50)
...both preferably with a flanged 14 or 15mm hex head but will accept the standard (for M10 bolts) 17mm hex head if necessary.
Our product was designed by "professional" engineers without standard hardware in mind. We're now out of our original special order stock and are trying to track down another source of replacement prior to placing another (expensive) special order.
I've tried numerous searches on the 'Net, but either the info isn't there or I'm simply not searching the right text. (When searching for the bolt sizes, I have found a couple listings overseas. Shipping costs kinda/sorta knock them out out as viable.)
I'd try to search the local AutoZone shelves but they said, "No," when I asked to search tie-rod ends for a project.
Thanks in advance to anyone who helps.
Keith W
http://mysite.verizon.net/vzeyv9ek
Toyman01
Toyman01 GRM+ Memberand Dork
3/3/10 7:41 p.m.
There is a place here in Charleston SC called Metric Nut and Bolt. They probably have them on the shelf.
Name: Metric Bolt & Nut Company Inc Street: 3359 Meeting Street Road Charleston, sc 29405-7976 Phone: (843) 566-0060
Not sure on the head bolts, but you might give these guys a call.
RealMiniDriver
RealMiniDriver Dork
3/3/10 7:59 p.m.
M10x180x1.5
Nothing longer in that diameter from McMaster-Carr. Would threaded rod work, with a nut on the end?
M10x300x1.25 threaded rod
RealMiniDriver
RealMiniDriver Dork
3/3/10 8:06 p.m.
M6 x 350 through M64 x 600
No price info, but they'll make any bolt you need.
zomby woof
zomby woof HalfDork
3/3/10 8:14 p.m.
If you can't find a flange head, you can use a 3/8" L9 washer.
93gsxturbo
93gsxturbo Reader
3/3/10 8:26 p.m.
Try calling ARP.
REW5XVvg4DFGawlpP3PzhfmOJhYaKRAY3BVhuZkYHiJC3NPXQ2hkiMKu89xy3vTO
