mtn
MegaDork
3/17/17 10:37 a.m.
I’m about to build a hockey net for my basement, but I have one difficulty that I can’t quite figure out a good solution to that is within my capabilities. Hockey nets are ridiculously expensive, or ridiculously poor quality. I’ve had some PVC ones before; they die in short order. So I’ve decided to build one. The basic idea is to use galvanized pipes and fittings, and make a goal frame. Should be about $35-50 in steel, plus the net which I can get for free when a rink disposes of their old ones (I’ll mend it with old laces)
The problem I have is how to attach the net to the goal. The easy way is to just tie (or ziptie) it to the pipe, like this:
Problem with that is, I’ll eventually break it with shots. I know, because this happened with my net that I had as a kid. Still the probable solution, but I’d like something a little better.
Real nets are attached to the goal with little welded on eyelids like this:
I can’t do that since A)I don’t have a welder, and B)I’m not a good enough welder. I thought about drilling holes in the back and attaching eyelids somehow, but that doesn’t seem like a smart solution (100 holes drilled in steel? I’ll burn through a lot of drill bits)
Anyone else have any smart ideas? I’m also open to using different materials; I really don’t care if the posts are round or not.
java230
SuperDork
3/17/17 10:45 a.m.
Stainless safety wire instead of zip ties? Should last a bit longer.
elastic cable ties instead of zip tie?
Or just replace the zip ties as they eventually break (not sure how often this would be)?
Worm gear hose clamps? Stainless steel cable ties?
mtn
MegaDork
3/17/17 10:48 a.m.
Often enough that it isn't the best solution. (I have a heavy shot)
Steel wire isn't a bad idea.
mtn
MegaDork
3/17/17 10:51 a.m.
Will be exploring both of these as well. Thanks!
Grizz
UltraDork
3/17/17 10:53 a.m.
Why not get bigger zip ties?
Doubt you'd break the ones we use for flex ducting. Or the ones they use as handcuffs.
mtn
MegaDork
3/17/17 10:57 a.m.
Got a link?
But have you ever seen/held a hockey puck? It is hard rubber. My slap shot is around 80MPH (well, it was at one point in my life...) Would it hold up to that?
Grizz
UltraDork
3/17/17 11:02 a.m.
http://www.homedepot.com/p/Malco-36-in-Nylon-Adjustable-Tie-25-Pack-TY34/100520678
Now I'm not sure how they'd hold up to a hockey puck but they're cheap enough that you can try them out and see how long they last.
as the zip ties get stronger and stiffer, you will start fraying and tearing the net I think. I'd get some nice synthetic cord and just wrap one long piece around and around and around the bar to "sew" the net to the frame.
T.J.
UltimaDork
3/17/17 11:24 a.m.
In reply to Robbie:
That is about what I was going to say. If the net itself is strong enough, I'd use similar cordage and tie it to the frame.
Got a link?
Yeah, but are you shooting at 80mph (and making a goal) every single shot?
mtn
MegaDork
3/17/17 11:40 a.m.
T.J. wrote:
In reply to Robbie:
The thing though is that the net really isn't strong enough. The puck is shot into the netting, the netting absorbs the puck and slows it down, and stretches as it does so. No big deal. But if you put a backstop on it (i.e. the goal post) then it changes the equation.
Go get a slightly dull knife--sharp, but not extremely sharp, and a rubber band. Holding the rubber band between your fingers, push down with some force using the knife. Chances are the knife isn't cutting through it. Now put the rubber band on the desk, and push down with the same amount of force. Now the elasticity doesn't come into play. There is no where for the energy to go, and the band breaks.
Same idea with the netting. And it likely isn't just one shot that does it, but over time it weakens.
mtn
MegaDork
3/17/17 11:42 a.m.
failboat wrote:
Got a link?
If I was hitting the net every shot we wouldn't have to worry about this!
java230
SuperDork
3/17/17 11:44 a.m.
I still think safety wire or stainless zip ties are the winners
Cheap, 100 pack for $11
https://www.amazon.com/Vktech-100pcs-Stainless-Exhaust-Locking/dp/B00CTKBTH2/ref=pd_bxgy_263_img_3?_encoding=UTF8&psc=1&refRID=H4X9DZEA8DWGDYHF3N8P
GSmith
HalfDork
3/17/17 11:51 a.m.
Hm. Since it's for practice - can you use sheet metal instead of netting?
Audio feedback for every goal... CLANG!
I like the wrap-with-cord idea, but java230 posted my other idea with the stainless zip ties. You'd need to put something under them, though, or I figure they'd cut the net.
Good to know that there is more than one genius on this forum!
This is the answer. Paracord and "sew" it to the frame.
Grtechguy wrote:
shower curtain rings?
Not bad.
I'd go with tieing it on with cord. I think it will be more forgiving than the zip ties or steel wire.
mtn
MegaDork
3/17/17 12:37 p.m.
Why didn't I think of paracord?
This is probably the answer. Super cheap, and it even comes in red too, which will match the goal frame once I paint it (after I actually, you know, build the damn thing)
mtn
MegaDork
3/17/17 12:38 p.m.
Wall-e wrote:
Not bad.
You could easily pass for 18
jstand
HalfDork
3/17/17 12:51 p.m.
Instead of doing that many eyelets, why not combine that with the cord idea?
Space the eyelets out, and then weave the cord through the net, passing the cord through the eyelets.
If you check out the different videos for replacing the mesh on lacrosse sticks, you can find some methods to lace the cord and secure the net so it doesn't slide on the cord to minimize sag.
on edit:
Example of lacrosse stringing
so, upon further review:
You say you want to send hockey pucks flying at 80mph inside your basement. You also say that you don't always hit the net (not holding that against you - who does?).
I've suddenly become much more worried about just about everything else in your basement than the cord or zipties holding the net on....
mtn
MegaDork
3/17/17 5:16 p.m.
Working that out still. I don't miss the net by much when I do (I'm a pretty good shot), but I'll need to figure something out. In my parents basement growing up we hung tarp to take the impact. I can't do the same here, but there will be something. Maybe an old mattress. The big concern will be shots off the cross bar that fly up.
