93EXCivic
93EXCivic SuperDork
1/10/12 12:23 p.m.
Saw this on the local autocross board.
DEFINITION OF ACCELERATION
One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500.
It takes just 15/100ths (0.15) of a second for all 6,000+ horsepower (some believe 8,000 HP is more realistic - there are no dynamometers capable of measuring) of an NHRA Top Fuel dragster engine to reach the rear wheels.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures 7,050 deg F. (Oxy-acetylene on "cut" is 6,300)
Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during one pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading this sentence.
Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout, the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
The current top fuel dragster elapsed time record is 4.428 seconds for the quarter mile (11/12/06, Tony Schumacher, at Pomona , CA ). The top speed record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony Schumacher, at Hebron , OH ).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The 'tree' goes green for both of you at that instant.
The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him.
Think about it...from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
...... and that my friend, is ACCELERATION!
1988RedT2
1988RedT2 SuperDork
1/10/12 12:38 p.m.
Wow. Last time I read that I was so surprised I nearly fell off my dinosaur!
cwh
cwh SuperDork
1/10/12 1:26 p.m.
I don't care if has been posted many times, it makes a cool read.
N Sperlo
N Sperlo SuperDork
1/10/12 1:30 p.m.
Sounds to me the writer has a hard on for Dodge.
Otto Maddox
Otto Maddox Dork
1/10/12 1:32 p.m.
Seems like we should be able to cure cancer if we can do this.
Appleseed SuperDork
1/10/12 1:34 p.m.
There hasn't been a Chrysler part in a Top Fuel car in years.
We don't know how much a top Fuel engine makes. There is no dyno powerful enough.
EastCoastMojo
EastCoastMojo GRM+ Memberand SuperDork
1/10/12 1:35 p.m.
For some reason, my brain reads this definition in Evel Knievel's voice.
Jay_W
Jay_W Dork
1/10/12 1:35 p.m.
I've kept this in my files for a long time. It's still impressive, every time I read it. I'm not a huge dragrace fan but the mechanics of what's needed to do what they do is just awesome...
DrBoost
DrBoost SuperDork
1/10/12 1:51 p.m.
N Sperlo wrote: Sounds to me the writer has a hard on for Dodge.
How's that? It said the Hemi is too wimpy to even turn the supercharger on a TF car. If that's having a "hard-on" for Dodge, then I guess I think Sandra Burnhart is kinda cute.
93EXCivic
93EXCivic SuperDork
1/10/12 2:16 p.m.
I guess I am the only one who hasn't seen that.
Giant Purple Snorklewacker
1/10/12 3:19 p.m.
93EXCivic wrote: THE DEFINITION OF ACCELERATION!
Less exciting but more accurate: a = (Vf - Vi) / t
EdenPrime
EdenPrime Reader
1/10/12 6:41 p.m.
Otto Maddox wrote: Seems like we should be able to cure cancer if we can do this.
They did cure cancer. Source: http://nutritiondietnews.com/853757/
Will
Will Dork
1/10/12 7:01 p.m.
Been a while since I took physics, but...
A=F/M
Right?
John Brown
1/10/12 8:54 p.m.
No...
AA/F:
stuart in mn
stuart in mn SuperDork
1/10/12 9:27 p.m.
Maybe if you're a slow reader.
Knurled
Knurled GRM+ Memberand Dork
1/10/12 10:04 p.m.
EastCoastMojo wrote: For some reason, my brain reads this definition in Evel Knievel's voice.
Does he talk rreeeeaaall ssslllooooowwww?
Because that's the only way I could stretch that one sentence out to five seconds.
At least this version didn't have the tripe about the crankshaft twisting 20 degrees after every run.
The engines physically cannot be "on the verge of hydraulic lock" either. 500ci times 270 rotations divided by a guesstimated 6:1 CR equals about 22500 cubic inches of chamber volume per run. That's close to 100 gallons. IF we accept that they run the engines at a 1:1 ratio of fuel:air by weight, and if the air is getting compressed to the same density as the incompressible fuel, that's still 50 gallons of fuel required... Not happening.
SVreX
SVreX SuperDork
1/10/12 10:37 p.m.
In reply to 93EXCivic:
I hadn't seen it. Thanks for posting!
The_Jed
The_Jed Reader
1/10/12 11:47 p.m.
That's the first time I've read that.
Friggin' wow! Even if there may be a few inaccuracies, friggin' wow!
PVHq95AnOYWrkqUUhmyUx9kW2sl75yZ95m11aGBBHqpqLV2zRpzRCcdGklTdVCed
