Enyar
Enyar Dork
8/29/15 12:39 p.m.
I store a boat at a friends house and this drives me insane. He has a big tub of what used to be transmission fluid he drained from his truck. Unfortunately he never disposed of it so it's just sitting by his house and every time it rains it over fills onto the ground and what's left in the tub becomes more and more diluted with rainwater. Can I dump this at advance auto parts with the oil? Or is there a better option that just killing the aquifer?
glueguy
glueguy GRM+ Memberand HalfDork
8/29/15 12:56 p.m.
That's what I would do. The water will separate easily. Under normal circumstances it's not nice to mix oil and water but I think this case warrants it and is the better choice than leaving it as is.
Ranger50
Ranger50 PowerDork
8/29/15 1:01 p.m.
I have the same issue with motor oil. I just dump it all, oil and water, at the nearest FLAPS. They haven't said a word to me otherwise......
madmallard
madmallard Dork
8/29/15 1:33 p.m.
i believe it goes through a seperating process as one of its very first steps anyways, so I think it should be fine too.
novaderrik
novaderrik UltimaDork
8/29/15 2:54 p.m.
at this point, just letting it get more and more diluted with rainwater seems like the easiest solution..
AngryCorvair
AngryCorvair GRM+ Memberand UltimaDork
8/29/15 4:56 p.m.
Oil doesn't get diluted by water. Water is heavier, so it goes to the bottom. Oil floats on top. If water gets high enough, oil spills over the edge. Could this be the "dilution" you're seeing?
Toyman01
8/29/15 4:59 p.m.
Have you ever considered smacking him upside the head and telling him to grow the hell up?
Dump it at the auto parts place. Their counter jockeys don't care.
captdownshift
captdownshift GRM+ Memberand UltraDork
8/29/15 5:39 p.m.
Combust the fluid off the top and be left with water and leaves
Enyar
Enyar Dork
8/29/15 6:32 p.m.
Well I emptied 35 quarts worth and there was still plenty left. You're right, most of it was water which had separated from the ATF/Oil. I actually think it's oil and not ATF. Smelled like balls and looked like a chunky milkshake. I'm going to dump the 35 quarts at advance and then refill. It's out of the rain for now.
SVreX
SVreX MegaDork
8/29/15 7:39 p.m.
The oil doesn't get diluted, but the tub does.
Letting it sit forever let's the oil run out as the water level rises. It all gets dumped on the ground, whether you do it quickly or bit by bit.
Apis Mellifera
Apis Mellifera Reader
8/29/15 10:09 p.m.
Is this no longer relevant?
novaderrik
8/29/15 11:01 p.m.
Apis Mellifera wrote: Is this no longer relevant?
my grandpa used his drain oil to "pave" his redrock driveway.
8/30/15 9:16 a.m.
Too bad it's diluted (or more accurately "floated away"), I was going to stay stand way back and toss in a match
faGy81QLNZk1R8FR0qQLB8jOFUFtk2tzt7Ibi4CQzFXJzlJcHiy1RCpQqDA0vBZ6
