2/19/22 2:22 p.m.
Not because I won't sleep another night without a Studie, but because I'm curious.  On the left side of this 3-spd manual tranny, what is the canister with wires into it?  Too far aft to be a starter, don't think it has overdrive (but it could).  It's a 1959 Lark if that helps.
DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
2/19/22 2:29 p.m.
preach (dudeist priest)
preach (dudeist priest) GRM+ Memberand Dork
2/19/22 2:30 p.m.
Dan, no clue on the Stude, but anything happening on the 911?
2/19/22 3:46 p.m.
Nah.  Was supposed to see my friend John today but with so much snow and ice I can't get there.  I suspect he's going to spend way too much money to fix it up and give it to his nephew, who is technically the next of kin.
I will be helpful and supportive but my hopes are not high, i.e. Go find a damn title yourself.
I can.
As our knees become less pliable or the Earth getting smaller, that 914 seat gets closer to the ground every summer!
2/19/22 4:36 p.m.
Where's the OD activator?
2/19/22 5:21 p.m.
In reply to 914Driver :
It's the silver T handle under the dash to the left side of the column. If you zoom in you can see the letters OD on it.
Stealthtercel
Stealthtercel Dork
2/19/22 7:04 p.m.
You've triggered a memory!  After trading his 1950 Hudson in about 1961, my Dad briefly had a 1958 Ambassador with a V8, stick, and overdrive.  The OD was operated by a black thing like an organ pull.  Haven't thought of that (or that car) in years.
ddavidv
ddavidv UltimaDork
2/20/22 11:21 a.m.
Vice Grip Garage just did a Packard with an overdrive. It's curious, because it seems to have both a cable operation and one of those big-arse solenoids as well.
2/20/22 11:42 a.m.
Once engaged, what is the advantage?  I mean, kicks in a hidden gear out back or in the transmission?  Curious what the final drive ratio is when engaged.  My old Honda V-75 Magna had an OD, engaged the final is 0.75 : 1, good cruisin' bad on hills.
stuart in mn
stuart in mn MegaDork
2/20/22 12:06 p.m.
The overdrive unit was on the rear end of the transmission.  Besides reducing engine rpm around 30% they also provided a freewheeling function.  Here's a manual for the Borg-Warner overdrive; this is posted on the Studebaker club website but many other manufacturers used the same unit.  http://www.studebakerclubs.com/NorthGeorgia/Overdrive.pdf
2/20/22 1:54 p.m.
You guys are resourceful!  Thank you.
Jerry From LA
Jerry From LA SuperDork
2/21/22 3:19 p.m.
Good to see the anti-rust oiler is working well.
Axexi58SDzbeW1zF5cf0GLn3Y3F1t2KHQJ05XBwemsgxcaLtXuy6cMOw5a2MIXC8
