DeadSkunk
DeadSkunk UberDork
11/8/17 11:38 a.m.
We have extremely hard water. Enough iron to leave rust stains on the side of the house if you aren't careful aiming the lawn sprinkler. Even with a water softener there is significant build up on the shower stall walls and the bath tub. It's a regular job to scrub this stuff off. Last time I used those green #M scrubbing pads. My knees and shoulders don't take well to the effort it takes, so I need a tool. The little shower scrubber power tools won't touch this job.
I have thought about using my buffer and some liquid rubbing compound. Anyone have a better idea?
Needle scaler and an air hammer. At like 20 psi... cheeky
sobe_death
sobe_death Dork
11/8/17 1:20 p.m.
You need the right cleaner. For me, it's between KABOOM! and Super Iron Out sprays for the bathroom where a sponge will remove the stains after a short soak.
DeadSkunk
DeadSkunk UberDork
11/8/17 1:24 p.m.
Start with cleaning the shower, and end with a full bathroom renovation?
DeadSkunk
DeadSkunk UberDork
11/8/17 1:25 p.m.
In reply to sobe_death :
Super IronOut has little impact on this stuff, unfortunately.
KyAllroad (Jeremy)
KyAllroad (Jeremy) PowerDork
11/8/17 1:34 p.m.
Cordless drill and scrubby 3M pad on a chuck.  HF sells a variety of them.
Greg Smith
Greg Smith HalfDork
11/8/17 2:46 p.m.
or maybe a random orbital sander but with 3m pad?
RossD
RossD MegaDork
11/8/17 2:52 p.m.
Fix the problem first. Contact a water treatment outfit; the water softener is obviously not enough.
imgon
imgon Reader
11/8/17 2:56 p.m.
Before we got our acid neutralizer our dishwasher would get brown and we would run the washer through a cycle with Tang (the powered drink mix) instead of soap and it cleaned it back to white. You could maybe try that but as RossD suggested a proper system will clean whatever is in the water out before hand. Our issue was manganese (sp) and it was eating the pipes from the inside out.
EastCoastMojo
11/8/17 3:26 p.m.
Vinegar. Distilled white vinegar. This can be diluted 50-50 with water and sprayed directly on the stains. Let it sit for a few minutes to loosen the stain and then hit it with your 3M pads.
The0retical
The0retical SuperDork
11/8/17 3:33 p.m.
There's a couple of whole house iron filters out there for like 400ish dollars that work in tandem with softeners.
Other than that I use uncut CLR when build up gets bad.
uxY7nbR1bvaj3oR32CqpcPFvQJnaE4t84ppKau4FSUpNlW87cQjMTKkoi0e7Guwg
