Mr_Asa
Mr_Asa UberDork
6/2/21 5:35 p.m.
Kinda a dumb question, right? I figured there might be something else in them to help them flow or something else like that and wanted to make sure.
Trying to figure out cause I was going to make some wire rope guides as we discussed here.
TVR Scott
TVR Scott GRM+ Memberand SuperDork
6/2/21 7:04 p.m.
Yeah, pretty much.
It'll be the 316L variety - for "low lead".  That's the alloy they use for pipe welding and such.
Should be totally fine for your wire guides.
Mr_Asa
Mr_Asa UberDork
6/2/21 8:39 p.m.
In reply to TVR Scott :
Appreciate it
Honsch
Honsch Reader
6/2/21 10:23 p.m.
L is for low carbon, not low lead.
The rods are stamped with the alloy they are, not for what you weld with them.
TVR Scott
6/3/21 6:54 a.m.
Argh, I knew it was low carbon.  I have no idea why I wrote that.
Kendall_Jones
Kendall_Jones HalfDork
6/3/21 8:39 a.m.
In a pinch I once used safety wire for filler :)
ShawnG
ShawnG UltimaDork
6/3/21 9:32 a.m.
A motorcycle builder I know slices off a strip of the metal to be welded and uses it for a filler rod.
You can't see the seam once it's polished, pretty incredible work.
zm5QE6IvzwazsEDIls2QgsEpPmavvcNPjGKeF5PsApQYuyZgtLzIKGIsFwvX4pGD
