alex
alex UberDork
12/28/14 1:07 p.m.
Last time I bought a TV it had tubes. I want to mount a modestly-sized flatscreen in our living room (36" is my upper limit for width - it's going between two windows), and 99% of its use will be streaming Netflix or Prime, likely through a Roku stick. I'll be wiring it up to a basic stereo, since our room isn't really conducive to proper surround sound.
I have a $500 upper price limit, which I'd like to stay as far under as possible in order to budget in mounts and clean cabling, etc. Obviously I'm not the sort that needs the bleeding edge of TV technology, but I want something that won't be obsolete next year, and primarily something that will last a good long time. I'm also not opposed to used, if there's a solidly reliable option worth pursuing there.
Where should I start?
BoxheadTim
BoxheadTim GRM+ Memberand UltimaDork
12/28/14 1:14 p.m.
Cheapest Full HD TV you can find at Wally World or Worse Buy would usually be a good starting point. It will be a noticeable upgrade over a SD tubey TV.
The Full HD part is kinda important, though - at that size, you will notice a difference between 720p and 1080p.
Ditchdigger
Ditchdigger UltraDork
12/28/14 1:28 p.m.
Watch out for the "soap opera effect" I had my first experience with it this week and was unnerved by it. Everything on that TV looked like a soap opera. People were too shiny shadows were too defined.
From what I understand it can be adjusted or turned off. The movie scrooged looked like....well. A damned soap opera.
Hatari was unwatchable with it. It made the old movie look modern which in turn made all the acting and dialog seem amateurish, hokey and corny.
It is as if every forehead had a light of its own. So shiny.
BoxheadTim
12/28/14 1:33 p.m.
Most TVs need to be adjusted from the screaming brightness settings to make them look "good" in the shop to something more sensible. Both of our LCD TVs have a bunch of presets that make the picture look half decent at least without too much fiddling.
Lancer007
Lancer007 Dork
12/28/14 1:55 p.m.
Yeah, setup is important. It was a week or so before I got used to the first HDTV after upgrading from a tube. Once you decide on a TV, Google the model# and settings and you'll find some good starting points and what stuff to turn off or on.
Woody
Woody GRM+ Memberand MegaDork
12/28/14 2:08 p.m.
Learn lots of stuff here:
http://www.rtings.com/info/lcd-vs-led-vs-plasma
kylini
kylini Reader
12/28/14 2:10 p.m.
At 36 inches, 720p is fine. Just get the latest Vizio on Amazon for about $250 and you'll probably be good. The only thing that matters is picture quality and, for that matter, contrast. If that's good, who cares if the TV has smart features you won't necessarily want to use.
Lancer007
Lancer007 Dork
12/28/14 2:59 p.m.
Is that 36" between the windows or are you talking about a 36" TV screen?
If it's a 36" space to fill then you could probably fit a 38-40" TV screen in there depending on how large the TVs frame is. At that size I'd definitely go 1080.
Dr. Hess
Dr. Hess MegaDork
12/28/14 3:41 p.m.
30" at Sam's was $168. "They Say" monoprice for the mount. Haven't bought a mount from them, but I buy cables there.
neon4891
neon4891 UltimaDork
12/28/14 3:49 p.m.
Lancer007 wrote: Is that 36" between the windows or are you talking about a 36" TV screen? If it's a 36" space to fill then you could probably fit a 38-40" TV screen in there depending on how large the TVs frame is. At that size I'd definitely go 1080.
This, 36" space should fit a 40". You won't find many TVs over 32" at 720, so resolution shouldn't be a concern.
I'm not sure what the general consensus on it is, but I personally like the one device/one remote simplicity of a smart TV. If it is in your budget I would consider it.
A Vizeo smart LED in 40" is 36.1" wide and under $400.
Dr. Hess
Dr. Hess MegaDork
12/28/14 4:27 p.m.
40" at Sam's was $268.
Woody
12/28/14 5:15 p.m.
I just bought this at BJ's for $299:
http://www.bjs.com/samsung-40-led-tv-1080p-60hz-120hz-cmr.product.279877?dimId=2000157+4294953006
chrispy
chrispy HalfDork
12/29/14 8:05 a.m.
The Vizio Netflix and Amazon Apps are pretty good; launch from the remote. If you already have the Roku stick, it'll do the same things as the Smart TV. We've had our 55" Vizio for a little over a year and have been happy with it. I recently hardwired it due to Netflix constantly buffering (I blame our router, not the TV) and it's improved dramatically. It replaced a 28" tube we had for a dozen years.
Advan046
Advan046 SuperDork
12/29/14 8:41 a.m.
Buy a Plasma TV. WAY better than any other technology, more cost but better.
As an engineer and car guy I am super sad to see TV manufacturing turn away from Plasma TVs because consumers just want cheap lcd. It feels like we are OK letting the Miata die in 1992 with no sales in the whole year, no one buying a neon ACR, no mustangs or golf GTI's. Nooooo lets all buy the carbureted 3 cylinder, CVT, 18MPG highway 5 seater wagons, robotically driven carriages.
G-R-R-R !!!!!
Rusted_Busted_Spit
Rusted_Busted_Spit GRM+ Memberand UltraDork
12/29/14 10:26 a.m.
In reply to Advan046:
Yep.
alex
alex UberDork
12/29/14 7:05 p.m.
Thanks, gents. This gives me a place to start, whereas before I was casting about in the dark.
Brett_Murphy
Brett_Murphy GRM+ Memberand UberDork
12/29/14 8:38 p.m.
If you have a recycling center near you, check it out now. I was just dropping off our household recycling and there were at least 6 flat screens in the electronics recycling area. I asked the workers if they were going to take them, and they said "no" because they already grabbed the good ones. One of the workers had set the others aside for his kid's school as a donation.
Beer Baron
Beer Baron UltimaDork
12/30/14 7:56 a.m.
Be sure if you get a 1080 that it is a 1080p and not a 1080i.
madmallard
madmallard HalfDork
12/30/14 11:23 a.m.
Does $500 include a wall mounting solution?
iTkUyQSd5KRH5Fs1h8EqQM7g0W80QsUOMbQiFJ2J1gLOossYsm8ly6m6P88Dh44T
