1 ... 1315 1316 1317 1318 1319 ... 1826
Toyman!
8/9/23 8:53 a.m.
Makes you wonder what they do next. What do you do with a 1200 pound body? I doubt it will fit in a crematorium...
Well, that was a rabbit hole. An XL crematorium will manage 1000 pounds.
https://blog.awkwardhuman.com/can-you-be-too-fat-for-cremation-46178df3619d
The most dramatic problem with overweight cremation is creating a runaway grease fire, although a seasoned operator knows how to avoid this. Less overtly dramatic is the movement of the deceased when they get that large. Just transferring them from a stretcher to a lift, or placing them in the retort is not without risk.
There are only a few options available to people that are morbidly obese (or anyone for that matter). If you can’t cremate, you have to bury. Much like buying an airline seat though, you may be buying multiple graves and an oversized casket if you don’t fit into a standard size space. Generally any sort of willed body program will dismiss the obese out of hand owing to the complications that go along with that.
Edit to add meme.
There's a point in a cremation where the meat cooked perfect - Meme by  Sketchdoes :) Memedroid
P3PPY
P3PPY GRM+ Memberand SuperDork
8/9/23 8:56 a.m.
RealMiniNoMore (Forum Supporter) said:
Lil Battery Hold Down
I can't decide which has better street cred:
Lil Carrier Assembly
Lil Differential
Although come to think of it they're also known as a pumpkin or a rear end...
bobzilla
bobzilla MegaDork
8/9/23 9:09 a.m.
May be an image of car and text that says 'i'm getting free Candy and your not'
Toyman!
8/9/23 9:16 a.m.
 Lil Slip Yoke.
The truck has no transmission so the drive shaft just sits in the snow -  Imgflip
Beer Baron
Beer Baron MegaDork
8/9/23 9:20 a.m.
L'il Chain Tensioner...
Kinky Blazing Saddles GIF | Gfycat
(or L'il Timing Chain Tensioner... not as kinky, but not bad.)
bobzilla
bobzilla MegaDork
8/9/23 9:21 a.m.
Lil' trunk release (it's been almost 6 months since I bought a car part!)
May be an image of text that says 'My brain: Do it. Me: Why My brain: Just do it. Me: Okay 3900200000'
Stampie
8/9/23 9:31 a.m.
In reply to Toyman! :
If there's a 1000lb limit I'm sure you could do it in batches and just put the ashes back together in the end.
RealMiniNoMore (Forum Supporter) PowerDork
8/9/23 10:10 a.m.
Beer Baron is winning, with Lil Chain Tensioner
8/9/23 10:10 a.m.
GCrites
GCrites Dork
8/9/23 10:15 a.m.
DarkMonohue said:
I scanned that picture and uploaded it to the internet over 20 years ago. It was out of a Dennis Kirk motorcycle accessory catalog. You're welcome, internet.
Ian F (Forum Supporter)
8/9/23 12:06 p.m.
akylekoz
akylekoz UltraDork
8/9/23 2:13 p.m.
Lil' Regulator
Lil' Bushing
Lil' actuator
Fuel Pressure
Rear control arm
blend door
Brett_Murphy (Agent of Chaos)
8/9/23 2:36 p.m.
Lil' Filter here.
Which is mostly true.
wvumtnbkr
8/9/23 3:09 p.m.
Lil' yoke.
Drew122
Drew122 New Reader
8/9/23 4:38 p.m.
Missing the third photo...  Those pens can be converted into little missile launchers by rearranging the parts just a little.  Re-insert the silver thumb clicker thing along with the plastic piece it's shown with in its regular place inside the top half of the outer casing.  Then insert the the spring and the other separate white plastic thingy.   Tamp it down with the ink cartridge until it clicks and stays put.  Then, aim at a safe target and push down on the silver thumb clicker thing.   Pew!
RevRico
RevRico GRM+ Memberand MegaDork
8/9/23 5:46 p.m.
fasted58 said:
Holy E36 M3, it gets better.
RevRico
8/9/23 5:50 p.m.
In reply to RevRico :
Meanwhile in Pennsylvania...
ProDarwin
ProDarwin MegaDork
8/9/23 7:18 p.m.
I saw that earlier and assumed it was fake because it's not an Altima.
fasted58
fasted58 MegaDork
8/9/23 8:13 p.m.
8/9/23 8:23 p.m.
For Toyman's crematorium research.
There's a moment during the cremation process when the meat is perfectly cooked. Mindblowing
8/9/23 10:03 p.m.
8/9/23 10:04 p.m.
MyMiatas
MyMiatas HalfDork
8/9/23 11:04 p.m.
It was a Toyota Corolla.
It was going 100+ MPH!
Woody (Forum Supportum)
8/10/23 7:21 a.m.
L'il Zip Tie.
Dusterbd13-michael
Dusterbd13-michael MegaDork
8/10/23 7:25 a.m.
Lil retaining clip
rxrZPikMOznwANG2tbyg2lrjq5xvHHK88iNxUeJwdCz2tCbxP8Foxlj1KcOtYBtw
