1 ... 1429 1430 1431 1432 1433 ... 1811
RonnieFnD
RonnieFnD Reader
12/8/23 8:57 p.m.
Not really a meme but it's funny tho.  We have picked random quotes and made them look like tech notes from Stellantis and then posted them all over the building.
RealMiniNoMore (Forum Supporter)
RealMiniNoMore (Forum Supporter) PowerDork
12/8/23 9:19 p.m.
fasted58
fasted58 MegaDork
12/8/23 10:42 p.m.
Ranger50
Ranger50 MegaDork
12/8/23 11:15 p.m.
RX Reven'
RX Reven' GRM+ Memberand UberDork
12/9/23 1:18 a.m.
RealMiniNoMore (Forum Supporter) said:
90BuickCentury
90BuickCentury Reader
12/9/23 7:19 a.m.
Mr_Asa said:
12/9/23 8:15 a.m.
Beer Baron
Beer Baron MegaDork
12/9/23 8:20 a.m.
fasted58 said:
I'd rather we make Veteran Benefits easier to get.
NickD MegaDork
12/9/23 8:54 a.m.
12/9/23 8:55 a.m.
Mr_Asa said:
Tightening the crank bolt on an Audi five cylinder.
It is really a bad design, the harmonic damper bolts to the timing sprocket, which is sintered and will break if the bolt comes loose.  Which it will because long cranks have a ton of torsional vibration and the harmonic damper does not bolt to the crank.
Torque spec is something like 263 ft-lb.
volvoclearinghouse
volvoclearinghouse UltimaDork
12/9/23 9:36 a.m.
volvoclearinghouse
12/9/23 9:37 a.m.
In reply to fasted58 :
Both this meme, and Beer Barons reply were political.
wspohn
wspohn UltraDork
12/9/23 9:52 a.m.
Do we really need labels like this?
12/9/23 1:04 p.m.
YES!
Nothing is idiot proof so I shoot for idiot resistant.
12/9/23 1:23 p.m.
Check out the label on a pack of disposable razors.
Every year we get a nostart that is because someone installed a battery and didn't remove the protective covers from the terminals.  This is at every place I have ever worked.
NickD MegaDork
12/9/23 2:05 p.m.
In the twelve years I've worked as a mechanic I've never seen that one, somehow. Nor the sparkplug as an oil drain plug either.
My favorite sticker I've seen was one on a distributor, sealing the cap to the body, that said "Warranty voided if removed". And just how are you supposed to install a distributor properly if you don't remove the cap?
RevRico
RevRico GRM+ Memberand MegaDork
12/9/23 2:17 p.m.
RevRico
12/9/23 4:52 p.m.
Floating Doc (Forum Supporter) GRM+ Memberand UltimaDork
12/9/23 5:04 p.m.
12/9/23 6:20 p.m.
In reply to NickD :
You need to work at an indie shop, where you get referrals from the FLAPS.
In hindsight I did never see it when I worked at a Saturn dealership.  I would say it would take a special effort to put a side terminal battery in with the protectors on, but I did see one where they tried to jam those little anti corrosion mats between the cable and the battery, at an indie.  All contact was through the bolt.
nderwater
nderwater UltimaDork
12/9/23 6:28 p.m.
12/9/23 6:31 p.m.
fasted58 said:
I just think this needs to be repeated.
12/9/23 6:33 p.m.
12/9/23 6:34 p.m.
12/9/23 6:34 p.m.
sE8vSkDkBxhskpgw39tmOYeQMilUJxH18bswec7rB0ZrFjtLPvXyvQKCLu4x3Yj8
