Rufledt
Rufledt SuperDork
8/21/14 8:36 p.m.
Ian F wrote: Repeat after me: FIT. IS. EVERYTHING. ON. A. ROAD. BIKE.
This. My road bike is a good fit for me except it is -maybe- a centimeter too long in the top tube. This caused a great amount of pain until I got aero bars:
(hotlinked from wikipedia for your amusement)
My bars didnt have pads up that high, but I could put my hands on the elbow pads which were about 2 cm higher and a cm or 2 closer to me than the normal bars. Doing this every now and then would help ease my pain. Of course, I could just get a shorter, higher stem, but I was young and stupid and thought aero bars would double as making me faster. They did, but a stem was probably cheaper
For reference, the stem is the part that says Ritchey:
That stem looks ridiculously long. That makes my neck hurt just looking at it.
Woody
Woody GRM+ Memberand MegaDork
8/21/14 9:45 p.m.
I'm too lazy to take these down for fancy pictures.
I still have my first bike. 1972 Ross Barracuda 16:
Ice bike (my current favorite):
Lunch break (I've never fallen on the lakes!):
Cannondale Rush 4, two Stingrays and a 1966 Sears Spyder.
My driveway chase bike. 1969 Schwinn Stingray Fastback frame, built up from assorted spares:
1969 Stingray Deluxe Two Speed, awaiting a sympathetic refresh, next to a 1966 Raleigh Rodeo Five Speed that may or may not get restored for my daughter:
1966 Stingray that was supposed to be stripped and powdercoated by now. Probably won't happen.
The road bike that I bought new and almost never ride. Probably Craigslist bound:
neon4891
neon4891 UltimaDork
8/21/14 11:07 p.m.
Making me want to refresh an early 90's dept. store Roadmaster MTB in my basement. I'm thinking some 2" cruiser tires, and knock it down to a 5 speed from 15.
donalson
donalson PowerDork
8/21/14 11:46 p.m.
neon4891 wrote: Making me want to refresh an early 90's dept. store Roadmaster MTB in my basement. I'm thinking some 2" cruiser tires, and knock it down to a 5 speed from 15.
I wouldn't be surprised if the crankset is a 1 price and the rings rivet on.... So you'll have to be commited if you really want to do a 1x5...
neon4891
neon4891 UltimaDork
8/21/14 11:59 p.m.
I was thinking new crankset...
Teh E36 M3
Teh E36 M3 SuperDork
8/22/14 7:00 a.m.
I've commuted 24 miles round trip for the past 5 years on this:
It's a very good cross between racer and mtn, with 1.5 tires I can curb jump, disc brakes (where have you been all my life?), and mine has a luggage rack. I have only crashed 5 times (ha ha- recovering from my last incident). Made it through DC winter last year with 3 days at 16 degrees in the AM.
ihayes
ihayes New Reader
8/22/14 7:35 a.m.
2000s Cannondale R600 here. Pretty much my only choice at the time for a 64cm road frame. With bro-some tribal graphics that were so popular back then.
Ashyukun
Ashyukun GRM+ Memberand Dork
8/22/14 12:03 p.m.
Teh E36 M3 wrote: It's a very good cross between racer and mtn, with 1.5 tires I can curb jump, disc brakes (where have you been all my life?), and mine has a luggage rack. I have only crashed 5 times (ha ha- recovering from my last incident). Made it through DC winter last year with 3 days at 16 degrees in the AM.
The only things I'd like to change on my Del Rey are wanting a higher ratio gear-set since I essentially don't use the low gears at all but am always wishing I had more gear to go up- and having disc brakes. Unfortunately the frame isn't set up for it so it would be difficult to convert it over.
donalson
donalson PowerDork
8/22/14 4:10 p.m.
do you mean lower gears? as in easier to pedal up hill? A triple or compact crank gives you a much lower gear rage then the old racing cranks... I'm going to guess you've got a 5spd out back? either way it's very likely you have a freewheel which can still be had inexpensivly but changing the gearing up front will make a bigger difference. http://www.jensonusa.com/!YPmbVkccC9B2oWv-QESB4w!/Sunrace-Multi-Speed-Freewheel?utm_source=FRGL&utm_medium=organic&gclid=Cj0KEQjw1NufBRCx8ayaqY2t6KkBEiQA2nLWm8VUrAZXDIDNHUGM-IYYSvKlPaipTAA24o9qXduhSu8aAkOA8P8HAQ
this shows how changing gearing front and/or back can change things... http://sheldonbrown.com/gears/
for stoppers... if you are using the old side pull calipers different pads can make a big difference but the modern double pivot design calipers will do even more for ya.
RexSeven
RexSeven UberDork
8/22/14 7:10 p.m.
If you want to change your pads, use Kool-Stop Salmon or Scott-Mathauser. I use Kool-Stops on my side-pull equipped Torpado and that bike stops on a dime. Both are very highly rated for stopping power, especially in the wet. Scott-Mathauser came up with the pad formula (secret ingredient- iron oxide. Yep, rust!), went under, Kool-Stop made a derivative of it, and now Yokozuna makes the original formula with S-M's blessing.
Kool-Stop Salmon at Harris Cyclery
Scott-Mathauser brake pads at Yokozuna
udcpaoBeUbJnWbI8kDE81m8QjuaqJMfH8V9MNOYbpheJBAaQPp3vucTK0HTCkTXE
