John Welsh
John Welsh Mod Squad
8/13/23 1:26 p.m.
I have this bike rack that is designed for a 2" receiver hitch.
It's a simplistic rack but it does have the option to pull the pin and the upright tilts for hatch opening w/o removal.  I paid $25 for the rack, used, a few years back.
I'd like to put a hitch on the Prius and use the bike rack with the Prius.  The challenge is there seems to be only one company that offers a 2" receiver hitch for a Gen2 Prius and that is Eco-Hitch @ $365 and listed elsewhere at $399.  I have not found anywhere cheaper and nothing used via FB or Ebay.
New, 1 1/4" Prius hitches go about $200-$150 for new.  I found a rusty used one about 1hr away for $50.  I then came across an Amazon return for $135.  I'm considering buying that.
The main question I have is, "in conjunction with the bike rack does an adapter like this seem like a good idea to you?"
Would a version like this be any better?
alfadriver
alfadriver MegaDork
8/13/23 1:36 p.m.
The only issue I would have with that adapter is that it sticks the bike rack out farther.
But I would suggest a different solution- get some 1" square tubing, and remake the rack.  That design is a pretty easy one to copy in a DIY manner.
OHSCrifle
OHSCrifle GRM+ Memberand UberDork
8/13/23 1:37 p.m.
For a bike rack only, I think I'd be comfortable using the first option.
No Time
No Time UltraDork
8/13/23 3:03 p.m.
I'd go with the second just for clearance, depending on the angle and height of the hitch when mounted on the Prius.
If you are concerned about sway and wiggle, use a couple cam straps from bike frames to the left and right side of the receiver hitch cross tube.
docwyte
docwyte PowerDork
8/13/23 4:55 p.m.
Either will be fine for a bike rack.  I wouldn't really put too much thought into one vs the other, just buy the one you like
Kendall Frederick
Kendall Frederick GRM+ Memberand Reader
8/13/23 5:00 p.m.
I have a 1 1/4" receiver on my Prius and there is a bike rack on it 95% of the time.  If you use the adapter ditch the pin that it comes with and use a bolt you can tighten.  Otherwise you double the opportunity for the rack to sway back and forth.
My 1 1/4" rack has a bolt instead of a pin for exactly this reason.
John Welsh
8/13/23 5:10 p.m.
Ohh, a bolt is a good idea.  Maybe I'll add two big fender washers too.  Or , a locking washer too
Curtis73 (Forum Supporter)
8/13/23 5:28 p.m.
This will sound like a strange suggestion, but how about a different rack?  I found dozens of really nice ones for $50.  I found one that fits both and has an adapter and a wedge-tightening thing to prevent rocking.  It's super sweet and was only $40.
You could also potentially contact the manufacturer and order just the insert part for a 1-1/4".  Probably two bolts to swap them out.
Another thought... weld a 2" chunk of tube beside the 1-1/4 receiver.  Nothing says the bike rack needs to be centered on the vehicle.  Or, if you'll never use it for anything but a bike rack, weld the 2" chunk of tube right over the 1.25" part.
neverdone
neverdone Reader
8/13/23 8:57 p.m.
I used the top one for a bike rack and a utility carrier.
porschenut
porschenut HalfDork
8/14/23 7:47 a.m.
How heavy is the load?  Honestly the adapter works, used it to carry a 50 pound 3 wheeler on a cargo tray.  Wobbled a lot but it was only a 3 mile drive.  The welding option also sounds good or the wobble eliminating clamps if you weld like me.
dps214
dps214 SuperDork
8/14/23 11:44 a.m.
I've used the first adapter on a cargo rack with no issues.
But instead of messing around with all that I'd just buy another <$50 bike rack that fits the hitch directly. I had good luck with the harbor freight rack, there is/was a slightly nicer version on amazon for a few bucks more if you're feeling fancy.
Wally (Forum Supporter)
8/14/23 12:19 p.m.
My
mother has been using a bike rack in the top one for a few years and it's been working fine. .
mtn
mtn MegaDork
8/14/23 5:34 p.m.
I would either use either of the adapters, or else pony up for the 2" receiver on the grounds of "The $200 difference is worth it so that I only have 2" receivers".
8/15/23 10:30 a.m.
Or just cut off the 2" insert and weld on the 1.25" one.
O4DStgj38QcG2WVduwzWDPvIcBXvKf4KBY4VZXN0Q61AQ6qpcODxyOO61MkfZbZY
