DoctorBlade
DoctorBlade UltraDork
6/23/13 1:26 p.m.
LopRacer
LopRacer HalfDork
6/23/13 1:54 p.m.
Clearly there is a snorkel for the intake and I love how the siren goes away as it enters the "puddle" and then comes right back on exit.
6/23/13 2:17 p.m.
air produced sounds do not usually travel well when submerged.
That was pretty cool though. I could not imagine the amount of cleaning needed after that
crankwalk
crankwalk GRM+ Memberand HalfDork
6/23/13 2:22 p.m.
Awesome!
EastCoastMojo
EastCoastMojo GRM+ Memberand PowerDork
6/23/13 2:34 p.m.
Sweet. Driver needs a scuba mask mounted periscope and his own air supply and he could easily drive through deeper.
GameboyRMH GRM+ Memberand UltimaDork
6/23/13 2:40 p.m.
LopRacer wrote: Clearly there is a snorkel for the intake
Yep you can see it around 0:56-0:57, a pretty common setup for lorries - an oil bath air filter under the cab, and then an intake running close to roof level at the back of the cab.
Grizz
Grizz SuperDork
6/23/13 2:56 p.m.
Flood waters are probably the least poisonous thing they had to deal with that day.
6/23/13 3:38 p.m.
the Isuzu I used to drive had the same setup
Gearheadotaku
Gearheadotaku GRM+ Memberand UltraDork
6/23/13 6:22 p.m.
I like how the driver opened the door for drainage.
hotrodlarry
hotrodlarry HalfDork
6/23/13 6:40 p.m.
wipers on for safety.
aussiesmg
aussiesmg UltimaDork
6/23/13 6:42 p.m.
"It's just a puddle."
"She'll be right mate."
"gurgle gurgle"
stuart in mn
stuart in mn PowerDork
6/24/13 7:43 a.m.
hotrodlarry wrote: wipers on for safety.
But they were only on the intermittent setting.
Curmudgeon
Curmudgeon MegaDork
6/24/13 7:47 a.m.
Yup, Isuzu builds 'em tough.
6/24/13 8:15 a.m.
the problems with that style Isuzu trucks is rust. Usually right under the driver's right foot. They only ever put a thin layer of vinyl on the floor and over time, the weight of the driver's foot rubs the paint off under the vinyl. Combine that with a small hole in the vinyl and wet feet from getting in and out of the truck all day.. and it does not take long for the floor to disappear.
Other wise, they are well equipped for that sort of work. Mechanical speedo and tach.. minimal electronics, mechanical fuel injection. As long as it can get air and fuel in and exhaust out.. that truck would ford water all day
pinchvalve
pinchvalve UltimaDork
6/24/13 8:23 a.m.
How did they know that would work? The water was almost to the roof? Firemen (and ladies) are a different breed, and for that, I am grateful.
SyntheticBlinkerFluid
SyntheticBlinkerFluid UberDork
6/24/13 8:29 a.m.
I like how the two firemen popped up from the back and the one was on the walkie the whole time.
"Get up there and make sure we aren't going to hit anything large!"
Brett_Murphy
Brett_Murphy GRM+ Memberand SuperDork
6/24/13 2:20 p.m.
What you don't see is that they ran over two Smart cars that were sunk under the water.
6/24/13 9:12 p.m.
In reply to Brett_Murphy:
That brush guard on the front probably came into good use then!
7msxMadfjiwuyyf1AHMe2Ji9e9WNsVCoCSRnRlgBjFAaYbQDC9K7gTjTnXEOrvbN
