rustybugkiller
rustybugkiller Reader
11/17/17 6:34 p.m.
How much weight can this loft rafter hold safely?
2x4s spanning 10’. 24” apart covered with 7/16” osb.
einy
einy HalfDork
11/17/17 7:00 p.m.
Get a deck building book from your local library and look it up.
spitfirebill
spitfirebill UltimaDork
11/17/17 7:17 p.m.
Not a lot.
SVreX
SVreX MegaDork
11/17/17 7:19 p.m.
No, you can't put an engine up there. cheeky
It's Spruce.  Spruce 2x4's have NO rating as a floor joist.
A couple hundred pounds evenly distributed.  No more.
rustybugkiller
11/17/17 7:27 p.m.
Too high for that. I'm using it mostly for light weight yard stuff. Possibly some wheels though.
spitfirebill
11/17/17 7:33 p.m.
I’ve got a similar setup and only put tailgating chairs, carpet scraps, a piece of a box of flooring, etc. on it.  Nothing real heavy, but it’s not sagging at all.
itsarebuild
itsarebuild GRM+ Memberand Dork
11/17/17 9:51 p.m.
Spam tables say 30 Psf  live and 5 PDF dead are about 8'-6" for that member and don't offer lower loads. If completely dead load (storage not people and movement) you could probably get away with a storage load (very evenly distributed) of 30 psf with a workable deflection. Just don't put any people load on it.
rustybugkiller
11/18/17 5:03 a.m.
In reply to itsarebuild :
Thanks! I may double up the 2x4s for added safety.
Patrick
11/18/17 7:23 a.m.
Put the wheels at the ends closest to the wall and the light stuff in the middle
1988RedT2
1988RedT2 UltimaDork
11/18/17 7:39 a.m.
Sister a 2x6 to each 2x4, floor it with plywood and load that sucker up?
Be safe!
SVreX
SVreX MegaDork
11/18/17 7:46 a.m.
I think you are mis-reading the span tables.  That sounds like the rating for 2x6 .
A #2 grade Spruce 2x6 on 24" centers with a 30 lb live load and a 5 lb dead load is rated for  8'-3" with a deflection of L/360.
The same specs for a 2x4 allow for a span of only 5'-3".
Here is a calculator:
American Wood Council span calculator
However OP, you will be fine.  You are not building a floor.  Doubling the 2 x 4's is a good idea.
itsarebuild
11/18/17 7:51 a.m.
In reply to SVreX :
i was looking at l/240. L/360 is overkill for deadweight storage.
KyAllroad (Jeremy)
KyAllroad (Jeremy) PowerDork
11/18/17 8:13 a.m.
Load it until it collapses.  Weigh that pile of crap.  Rebuild it exactly and reload it with 10% less crap.  Done!
Or follow the above suggestion and add some 2x4s to the span just for the sake of security.
bluej
bluej UltraDork
11/18/17 8:44 a.m.
If I was going to bother with sistering new boards in place, I'd go with 2x8's instead of just more 2x4's
rustybugkiller
11/18/17 11:10 a.m.
Oh, ok same way you set the boost on a turbo. Add boost till she blows, rebuild and dial back 10%.  Lol
Hal
Hal UltraDork
11/18/17 2:46 p.m.
In reply to SVreX :
Would you sister the 2 x 4's or put them between to make them 12" OC?
Asking because my BIL would like to put a loft in his similar shed.
KyAllroad (Jeremy)
11/18/17 3:14 p.m.
Hal said:
In reply to SVreX :
If it was my shed?  Most likely both.
SVreX
SVreX MegaDork
11/18/17 10:16 p.m.
itsarebuild said:
In reply to SVreX :
L/240 still comes up at 6'-0"
rustyvw
rustyvw GRM+ Memberand Dork
11/18/17 10:35 p.m.
I have a similar shed, and I've been in the loft moving things around.  I'm around 250, so  I can verify it will hold more than that.  I think it's more about the distribution than anything else.
58jQCscWL2B4mrqC3MPiR5xpHbQ2oRiRT65BoWwyz80DgmtMmXocBLJlhMssrlgk
