mad_machine said:
for what it is worth, I have never been in a theater that had sound deadening around the sound booth. most people mix from the Front of House (FOH) position just so they can hear what the audience hears. I understand wanting to put dampening in the half walls of the booth and the floor though. Spray Foam may be your friend in this case, just fill those open spaces and seal, should do a decent job of dampening the sound.
the "music box" at the Borgata has the sound booth out in the open like you show. I think your best bet is to do something about the slap you are getting from the back wall and prop storage. Heavy Duvateen or used curtains from a theater or prop house might help
Agreed on the heavy fabric. Only problem is that its about 100 linear feet of shelves that are 15' high. We're talking really big money for that project. Just to buy the Duve for the project would be nearly $3000 for the non-fireproof stuff which I would have to salt, or $4000 for the fireproof stuff. Then I would need a week to sew it all together. To put it in perspective, the last set I built was in a 40' proscenium, it was 18' high, had three houses with two levels, and it cost me $673. We just don't have the money right now to even consider such a project. The tech booth won't cost me anything since I have so much scrap material here.
I also wish I could put a finger on exactly where the "life" was coming from in there. Its fortunately pretty even given its symmetry... which means that most of the productions here can be equally misinterpreted from any seat. Here is another view of the space:
Years ago (around 1999) this building was converted from a proscenium theater into a production center. All of our productions for a while took place at a new, larger theater downtown. That proved to be not cost-effective, so we moved some of the productions back home here. When I took over three seasons ago, there were more exposed shelves with no curtains, no seating risers, and no lighting. The lights were literally halogen work lights hanging on trusses that were suspended from the ceiling. The light board was a piece of plexiglass with 12 residential slide dimmers in it with a snake of THHN hardwired into a subpanel. That firetrap was the first thing to go.
In 99 when this was converted, the main space you see above was a raked audience seating. The floor was raised up level with the stage. Now the former audience area is a black box theater, the former stage is now the lobby, and the former lobby is now costume storage. So the old proscenium arch is now covered with a curtain and people enter and exit through it. So, the shelving you see in the photo is covered with a lightweight (maybe 6oz) polyester woven fabric. It isn't quite opaque, but when you have lights on you can't see through it. Looks wonderful, but doesn't do much for sound. I think the upholstered furniture on the shelves does more. Walls are all drywall and portions of it are angled back and forth a bit (maybe 10 degrees).
I have a couple dozen of the 4'x8' sheets of hard woven fiber panels which I think I won't install until I get the shelves out. Not much wall space to install them right now.
For right now I'll likely just put foam inside the booth. I have enough for that. I may temporarily install some on the outside and just see what it does. I just don't want to make it worse for patrons or have a sound tech chew me out for doing something dumb.
