Spitsix
Spitsix Reader
4/11/11 9:20 p.m.
Just doing a little marketing study.
  1. Do you have a storage shed or garage with exposed wall studs?
  2. Do you have shelves in the shed / garage?
  3. What is the approx weight of items on each shelf?
Thanks Scott
4/11/11 9:24 p.m.
  1. Yes and yes
  2. no and yes
  3. not much.
EastCoastMojo
EastCoastMojo GRM+ Memberand SuperDork
4/11/11 9:39 p.m.
Spitsix wrote: Just doing a little marketing study. 1. Do you have a storage shed or garage with exposed wall studs? 2. Do you have shelves in the shed / garage? 3. What is the approx weight of items on each shelf? Thanks Scott
  1. Yes and yes
  2. Yes
  3. 30 - 50 lbs range
Wally
4/12/11 3:03 a.m.
1 No
2 yes
3 20-50 lbs
914Driver SuperDork
4/12/11 5:46 a.m.
Spitsix wrote: Just doing a little marketing study. 1. Do you have a storage shed or garage with exposed wall studs? Insulated garage, no shed 2. Do you have shelves in the shed / garage? One, for helmets 3. What is the approx weight of items on each shelf? Not much. Thanks Scott
DILYSI Dave
DILYSI Dave SuperDork
4/12/11 6:24 a.m.
Yes / Yes
Yes / Yes
Hundreds of pounds. The "lighter" of the shelves are 3/4" Plywood cut into 1' wide strips, mounted on the heavy duty braced angle that HD sells. These are mounted every 4'. The heavy shelves are (2) 2x10 (total width of 19") forming the shelves with stacked cinder blocks forming the columns. They are bomb proof.
EvanB
EvanB GRM+ Memberand SuperDork
4/12/11 8:18 a.m.
1. No
2. No
3. Nothing
ransom
ransom GRM+ Memberand Reader
4/12/11 9:31 a.m.
  1. yes, but not for long. Going to drywall to remove flying sparks' hiding places and paint white for better lighting.
  2. yes
  3. as much as 50 lbs/shelf, usually a bit less.
iceracer
iceracer Dork
4/12/11 9:35 a.m.
Yes Yes Never really thought about it.
Spitsix
Spitsix Reader
4/12/11 7:08 p.m.
Thanks Gang - Anybody else?
oldopelguy
oldopelguy Dork
4/12/11 7:12 p.m.
Yes Yes Several thousand lbs (I have over 50' of 3' deep x 10' tall pallet racking and a forklift)
Maroon92
Maroon92 SuperDork
4/12/11 7:13 p.m.
No garage. (Just making sure my outlier gets counted.)
friedgreencorrado
friedgreencorrado SuperDork
4/12/11 7:14 p.m.
Yes, studs.
No, using floor shelving. There are nails in the studs, I use them to hang old racetrack advertising banners.
Don't know, but nothing heavier than a master cylinder.
Spitsix
Spitsix Reader
4/12/11 7:46 p.m.
In reply to oldopelguy:
That may be a bit over the weight limit of my design!
Thanks - Scott
Grtechguy
Grtechguy SuperDork
4/12/11 8:56 p.m.
Yes/Yes
Yes/Yes
20-50lbs
foxtrapper
foxtrapper SuperDork
4/13/11 4:58 a.m.
1 yes 2 yes 3 each shelf? Varies from ~1 lb to +150 lb
1988RedT2
1988RedT2 Dork
4/13/11 6:17 a.m.
  1. Yes. 3-car detached garage.
  2. Yes. Every available inch of wall is covered with shelves.
  3. Hundreds and hundreds of pounds.
Toyman01
Toyman01 GRM+ Memberand SuperDork
4/13/11 6:43 a.m.
Spitsix wrote: Just doing a little marketing study. 1. Do you have a storage shed or garage with exposed wall studs? Yes 2. Do you have shelves in the shed / garage? As many as will fit plus stuff hanging from the roof. 3. What is the approx weight of items on each shelf? Thousands of pounds total Thanks Scott
z31maniac
z31maniac SuperDork
4/13/11 6:45 a.m.
  1. Yes / No
  2. No / Yes
  3. Not much, wrenches, battery charger, small generic socket set, some other rarely used things.
We will be tearing it all down anyway though. I've got plans to build a strong table that folds up to the wall when not in use, so two cars can still go in the garage. But with 1 car you can lay down the table and have a nice sturdy work surface.
Woody
4/13/11 9:36 a.m.
  1. Yes / No
  2. No / No
  3. NA
Lesley
Lesley SuperDork
4/13/11 10:45 a.m.
  1. I have a small shed on the back of the house with exposed studs.
  2. Free standing cabinets and shelving, none of it is attached to the walls.
  3. 30-50 lbs.
Brett_Murphy
Brett_Murphy GRM+ Memberand Reader
4/13/11 1:02 p.m.
  1. Both
  2. Both
  3. It depends on the shelf. Some hold a couple of bags with packing peanuts (maybe a pound) while others are holding a lot more, maybe up to 100 pounds.
I also have an open ceiling in the garage and throw body panels and other things across the roofing beams.
Giant Purple Snorklewacker
4/13/11 1:20 p.m.
  1. Counting myself, one exposed stud
  2. Yes
  3. 1 to 700lbs with the average probably somewhere near 10-30lbs but engines, diffs, gearboxes and wheels with slicks do make multiple appearances.
UqSW5UPDkei7D4d5hVRWwdDjHn4a8ZC0SMWH4HPT1TpJJheXzn6kbLO2UFJ67da4
