In reply to Duke :
We need a clapping emoji.
Toyman! said:The googles says "There have been 18 fatal accidents involving submersibles since 1915, resulting in 835 deaths."
That's an average of 7.6 people per year. Using that metric, 2023 was better than average.
I would be interested to see the accident rate strictly for research submersibles since then. I bet it's a lot lower, especially if your numbers include wartime casualties and military submarine figures...
codrus (Forum Supporter) said:Pete. (l33t FS) said:(given that they thought a material that is weak in compression would be a good idea for a submersible, in the first place, this is not really that surprising)
Apparently the carbon-fiber-with-titanium-end-caps design was based on a US Navy submersible called AUSS. That one was unmanned; but it had a pressure hull for bouyancy, went deeper than the OceanGate one did, and they did over a hundred successful dives in the 90s before retiring it. So perhaps the core idea isn't a crazy as everyone makes it out to be now?
AUSS was significantly smaller in diameter had no view ports and was likely not made with expired materials and glued ends. If you don't need to accommodate a human and breathing gasses you can do a ton more reinforcement on the inside. I trust the US military to build a AUV and I trust that they did not put a human inside it for a reason.
1988RedT2 said:I keep asking myself, how do people still consider this event relevant today?
The reason it is relevant today is that the public hearings into this cluster are ongoing this week and next week. That is why we are now seeing wreck footage, why the truth of the original venture is coming out, and why the things that have been investigated are now coming to light.
Yes, too much regulation is stifling to innovation. Testing of the original hull design for the Titan showed that it was inadequate for the specified working depth. Then, they had to replace the first hull because it de-laminated. The next one was built by a different method done so by different contractors, and the new method was untested. Then, they re-used the mounting rings and titanium domes from the old hull.
Mr. Rush at this point was basically hitting Murphy with a 2x4, daring him to do something.
That type of ignorance borders on the criminally negligent, especially since so many SMEs in the field warned Rush about it years prior.
2.4 miles beneath the waves is the last place you want to be "innovating" without spending millions on R&D and unmanned testing first.
I'm still scratching my head about the darned ratchet strap... can somebody suggest a reason why that was there?
In reply to SV reX :
Im betting it held skids or some external gear on. Normally you would bond that on, but given other shortcuts taken...
Wonder if it can be found in other pictures before failure? Might give a hint
SV reX said:I'm still scratching my head about the darned ratchet strap... can somebody suggest a reason why that was there?
It's not on the pressure vessel, that's the fairing for the tail. So while it's a really bad look, it's not a serious problem in itself. I don't see it in any of the pre-implosion pics.
Still chugging through this, it has the usual slowness of content as with any other livestream. But there are interesting tidbits.
One thing that I find interesting is how they turned a negative into a positive. I remember seeing an interview with one of the clients who was glowing about how the submersible was so small and so much had to be done that the people who paid to dive were tasked with certain jobs and given little titles.
ITV: They were called crew and not passengers, because the standards of safety are much higher if you have passengers.
Pete. (l33t FS) said:ITV: They were called crew and not passengers, because the standards of safety are much higher if you have passengers.
Why do I have a hard time being surprised by this?
Hard to remember if this video has already been linked...
Yahoo.com: Coast Guard releases video showing Titan submersible wreck at bottom of Atlantic
Also hydraulic press vs various tubing. It's interesting how the carbon fiber fails.
In reply to VolvoHeretic :
Cool vid to be sure, but that carbon fiber sample looks to have been made with a focus on aesthetics rather than structural strength. In addition, we don't know what adhesives were used in manufacture or how it was cured.
In reply to myf16n :
Fare enough. I know nothing about carbon fiber and for some reason, there are virtually no videos of destructive testing of it. You would think that over the years, someone would have made a video of a driveshaft or maybe a wheel spun to failure.
How about one more video in regards to OceanGate? Also, note to self: Never name anything that ends with "Gate".
