ignorant
ignorant SuperDork
1/9/10 1:13 p.m.
http://www.telegraph.co.uk/news/newstopics/howaboutthat/6946257/Mans-penis-removed-from-pipe.html (Semi-NSFW)
Ohh Good Gracious me...
neon4891
neon4891 SuperDork
1/9/10 1:26 p.m.
I almost called repost, but it seams this situation keeps repeting itself.
Stoopid people...
JoeyM
JoeyM Reader
1/9/10 1:27 p.m.
"I'm sure the man won't be getting into that situation again.''
On a side note, I'm glad to see that this was in the UK. I don't like the fact that the Sun has a whole section for weird things in the USA: http://www.thesun.co.uk/sol/homepage/showbiz/bizarre/usa/
Our tabloids should start a section on silly limey behavior.
DrBoost
DrBoost Dork
1/9/10 2:23 p.m.
"The anxious man aged about 40 gave hospital staff no explanation about how the pipe got stuck after he turned up on Tuesday morning."
I'd have said "uh, we ain't getting it out till you 'splain this to us all" and just waited.....
1/9/10 2:28 p.m.
tube steak has an all new meaning
Giant Purple Snorklewacker
1/9/10 2:44 p.m.
Seems like all they really needed to do was put him in a cold shower and it would fall off by itself. I'm guessing that somebody on the rescue squad was just itching to use and angle grinder on a hootis. Well, atleast they spared him the oxy torch.
mel_horn
mel_horn Dork
1/9/10 2:55 p.m.
Giant Purple Snorklewacker wrote: Well, atleast they spared him the oxy torch.
Or the pipe cutter...
Will
Will Reader
1/9/10 3:00 p.m.
Couldn't they have just...waited a while?
914Driver SuperDork
1/9/10 3:19 p.m.
Sure am glad Mom's vacuum cleaner was chrome and not stainless, eh?
Salanis
Salanis SuperDork
1/9/10 3:23 p.m.
Will wrote: Couldn't they have just...waited a while?
Actually, no. It constricts blood flow to the veins, since they're closer to the surface. So... blood can flow in, but it can't flow out.
JoeyM
JoeyM Reader
1/9/10 5:15 p.m.
Yup, that makes sense. The metal pipe was working on exactly the same principle as one of those little rubber rings that some guys put around their weiners (NSFW) to partially constrict the blood flow. Unfortunately for him , the pipe worked too well; i.e. it totally cut off the blood flow. If they hadn't removed the pipe he would have gotten gangrene and lost his lucky member.
mtn
mtn SuperDork
1/9/10 5:57 p.m.
Yup, that makes sense. The metal pipe was working on exactly the same principle as one of those little rubber rings that some guys put around their weiners to partially constrict the blood flow. Unfortunately for him , the pipe worked too well; i.e. it totally cut off the blood flow. If they hadn't removed the pipe he would have gotten gangrene and lost his lucky member.
This post needs a NSFW warning. And a don't go there warning.
Kramer
Kramer HalfDork
1/9/10 6:45 p.m.
That's just nuts...
924guy
924guy Dork
1/9/10 6:51 p.m.
Kramer wrote: That's just nuts...
nah, apparently, the nuts were okay.....
porksboy
porksboy Dork
1/9/10 6:52 p.m.
Makes me think. When we got carbide wedding rings in at work I asked how it could be removed at the hospital in the event of an emergency. They use vice grips to squeeze and shatter them. I woned if you could do the same with a cast iron pipe? Maybe guys should use cast iron pipes instead.
aussiesmg
aussiesmg SuperDork
1/9/10 7:00 p.m.
"a very steady hand" talk about your understatements
Wally
1/10/10 1:01 a.m.
JoeyM wrote: "I'm sure the man won't be getting into that situation again.'' On a side note, I'm glad to see that this was in the UK. I don't like the fact that the Sun has a whole section for weird things in the USA: http://www.thesun.co.uk/sol/homepage/showbiz/bizarre/usa/ Our tabloids should start a section on silly limey behavior.
They could do a section on just Floriduh
mel_horn
mel_horn Dork
1/10/10 8:48 a.m.
Maybe he was following the Cialis advertisement's advice "if you experience an erection lasting more than four hours,seek medical attention "...
BoxheadTim
BoxheadTim GRM+ Memberand HalfDork
1/10/10 9:07 a.m.
I'm sure he got their attention...
1/10/10 9:43 a.m.
I guess it was a pipe dream.
and yes, friend of mine was an EMT.. the stories he tells...
JoeyM
JoeyM Reader
1/10/10 4:49 p.m.
mtn wrote:
JoeyM wrote: The metal pipe was working on exactly the same principle as one of those little rubber rings that some guys put around their weiners to partially constrict the blood flow.
OK, I added a NSFW warning to the wikipedia link I posted above. I'm curious, though.....given the topic at hand, what did you expect to be at that link?
Wally wrote:
JoeyM wrote: On a side note, I'm glad to see that this was in the UK.
We resent^H^Hmble that remark
patgizz
patgizz GRM+ Memberand Dork
1/10/10 6:56 p.m.
porksboy wrote: Makes me think. When we got carbide wedding rings in at work I asked how it could be removed at the hospital in the event of an emergency. They use vice grips to squeeze and shatter them. I woned if you could do the same with a cast iron pipe? Maybe guys should use cast iron pipes instead.
maybe you shouldnt be putting your junk in pipes in the first place.
Jensenman
Jensenman SuperDork
1/10/10 8:18 p.m.
(smacks forehead with hand)
wRYDFgklw3b6jqBertmsgQzA6yKhtWcz0WqHIDSljxywvF2SAYuO6xsLg6eFX505
